Overturn Switch / Tip Over Relay - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Overturn Switch / Tip Over Relay (/showthread.php?tid=79993) |
Overturn Switch / Tip Over Relay - Old-Git - 22-08-18 Hi all mine is intermittently faulty. anyone know a way to bypass it? or a cheap source to replace it?TaNick Re: Overturn Switch / Tip Over Relay - unfazed - 22-08-18 I'm curious, how did you figure that out ??? :eek Re: Overturn Switch / Tip Over Relay - PieEater - 23-08-18 (22-08-18, 09:24 PM)unfazed link Wrote: I'm curious, how did you figure that out ??? :eek9K Tacho code. Re: Overturn Switch / Tip Over Relay - Old-Git - 23-08-18 (23-08-18, 07:05 AM)PieEater link Wrote: [quote author=unfazed link=topic=24469.msg283289#msg283289 date=1534969497]9K Tacho code. [/quote] Yep that and the relay making a very distressed noise when I switched the ignition on..... Re: Overturn Switch / Tip Over Relay - ram - 26-08-18 i had a cutting out problem when i 1st got my fazer (later found it was the imob) and i took my relay apart to check it. was easy to do and simple inside with not much to go wrong. i would have a look and clean it up if reqd Re: Overturn Switch / Tip Over Relay - unfazed - 26-08-18 Not really an item that gives much trouble on the fzs1000, for that reason I would risk a second hand one.Bypassed a few Suzuki ones and an old R1, unfortunately I never had an Fzs1000 on apart to see what was inside. My theory is usually that if something is not working open and see if it can be fixed. You can't break something that's already broken, as the worst you can do is fix it. If you do decide to open it post a few pictures of the internals. The R1 has a little pendulum inside it and track day users fill it with silcone to stop the pendulum. A severe enough tank slapper or very quick change of direction like two quick bends in succession can cause it to operate and cut the engine, unlikely to ever happen in normal road use. Re: Overturn Switch / Tip Over Relay - Old-Git - 27-08-18 Thanks all, it seems to have got better all on it's own (lack of use perhaps?) I'll try the silicone trick if it happens again. |
