Muc Off etc - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Muc Off etc (/showthread.php?tid=79952) |
Muc Off etc - NorthWestern - 10-08-18 Does anyone use these types of products? I have been using it for a bit (got 2 bottles at a closing down sale) but have noticed that whenever I need to do anything on the bike everything is bone dry rather than retaining any lubricant/grease! Changed the tires, the front pinch bolt on the forks was proper dry and took a fair amount of force. Likewise the spindle at the clamp end was bone dry and needed a lot of persuasion. Rear spindle was the same. My front brake lever was feeling a bit notchy so I took it off and cleaned/lubed the pivot points etc but again, the bolts,bushing etc were bone dry. You could say that maybe it was the bike but I have serviced these things since owning and always greased them up etc, never had a problem before using this muc off. Think I will give it a miss... Re: Muc Off etc - fazersharp - 10-08-18 Sounds like its a great de- greaser :lol Nothing more than a damp rag for my dry weather riding or paraffin dampened rag for oily type areas Re: Muc Off etc - NorthWestern - 10-08-18 Indeed sharpie! Car shampoo/Paraffin has always been my preference... Re: Muc Off etc - tommyardin - 10-08-18 Auto Glym car shampoo for all bike and to remove chain lube spots from the rims swing arm tops and the under side of the rear fairing chain side a rag with WD40 sprayed on it. Re: Muc Off etc - robbo - 10-08-18 Used to use it on my dirt bike, but that was continually being fettled. It must have some acidic content as you can't leave it on alloy for too long before washing off, as the alloy will start to discolour. Re: Muc Off etc - Bretty - 10-08-18 I used to use muc-off cleaner on my mountain bike... Before I realised it smelt the same as car windscreen wash, which is 5x cheaper, an awesome cleaner and proven safe on rubber, plastic and paint. I found it just as effective and assume it's the same stuff rebranded. ;-) Re: Muc Off etc - F4celess - 14-08-18 That Muc-Off should never be sprayed neat. It can actually permanently mark some materials if left too long, before being wiped afterwards. Perhaps this isn't noticed so much on a shiny bicycle frame. I tend to only wash my (Motor)bike now using a large bucket of warm slightly soapy water (Meguiars shampoo), and a wash mitt. Hose rinse the bike afterwards, before drying with a microfiber cloth. Re: Muc Off etc - celticdog - 15-08-18 (14-08-18, 04:53 PM)F4celess link Wrote: That Muc-Off should never be sprayed neat. It can actually permanently mark some materials if left too long, before being wiped afterwards. Perhaps this isn't noticed so much on a shiny bicycle frame. I'm the same, bucket of warm water and some car shampoo, if I've none in I'll use a squirt of washing up liquid. I probably only wash 4 times a year as I like it dirty( the bike that is). |
