How many different bits of bikes have you got fitted to yours? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: How many different bits of bikes have you got fitted to yours? (/showthread.php?tid=79874) |
How many different bits of bikes have you got fitted to yours? - 5LV - 18-07-18 In addition to the fazer that is. 5jj r1 forks 5pw yokes 5vy master cylinder R6 shock 4xv quill can Zzr1100 braided hoses Gsxr 750 fork springs Gsxr 600 footrest plates Re: How many different bits of bikes have you got fitted to yours? - Dynspud - 19-07-18 R6 shock from Devilsyam - and what a difference it makes!!
Re: How many different bits of bikes have you got fitted to yours? - Red Ceri - 19-07-18 1999 R1 - Forks 1999 R1 Frt Mud guard 1999 R1 - Lwr Yoke with Fazer Stem Billet Top Yoke SS1000R - Shock with Ohlins Spring 2003 R6 - Wheels FZ1 - Rear Caliper mount ABS (modified) FZ1 - Rr Disc FZ1 - Caliper 5VY - Frt Master Cylinder Unknown Year Yamaha Front Discs 320mm Diameter Re: How many different bits of bikes have you got fitted to yours? - Fazerjon - 20-07-18 2004 R1 forks, yokes & front mudguard, R6 rear shock. Re: How many different bits of bikes have you got fitted to yours? - ProdigalSon - 23-07-18 The only thing on mine is BMW S1000RR rear shock and Ohlins spring.
Re: How many different bits of bikes have you got fitted to yours? - Millietant - 06-08-18 LOL - it wasn't a Fazer, but this reminded me of the mods I made to a 1973 CB 500/4 in the mid 1980's. It had :- CB 550 F2 petrol tank CB 750 clocks (home made polished aluminium faces) CX 500 front forks, calipers, discs (drilled at work), wheel, yokes etc CBX 550 master cylinder CBX550 ignition coils CB 900 push-pull throttle and cables CB 900 switchgear CB 650 carburettors CB 650 footrest plates, pegs, brake lever, gear lever and associated linkages. Kawasaki Z 650 seat Kawasaki Z 659 tailpiece and tail light Spax RD 350 LC shock unit (home made monoshock rear end conversion) CB 400 N (Superdream) rear wheel Custom one-off exhaust Big bore kit (605cc if I recall) Yamaha XJ 650 headlight Lots of aftermarket other bits (finned casings, levers, stainless nuts/bolts etc) In the end, I think only the sidepanels and side stand were as Honda originally provided (Classic and Motorcycle Mechanics printed a little feature on the bike back in 2002) First incarnation was with CB 550K pipes and in sit-up-and-beg style) ![]() 2nd incarnation was in Cafe Racer style, with CB 650 rear-set plates, before everything else was re-fitted
Re: How many different bits of bikes have you got fitted to yours? - devilsyam - 06-08-18 A lot way to many to list Re: How many different bits of bikes have you got fitted to yours? - nick crisp - 06-08-18 (06-08-18, 05:52 PM)devilsyam link Wrote: A lot way to many to list Try listing what's still standard - shouldn't take long :lol |
