Fuel tank tap - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fuel tank tap (/showthread.php?tid=79847) |
Fuel tank tap - Russgreg1987 - 12-07-18 Hi, Has anyone ever purchased a new fuel tap? I’ve removed it to check the filter but in doing so the filter snapped off due to being very weak. Cheers Re: Fuel tank tap - daviee - 12-07-18 no longer made you will need to see if you can get a second hand one Re: Fuel tank tap - bandit - 12-07-18 You can still get brand new ones but at around £100 as said E bay used £10,but I was thinking do you really need the filter in the tap as our bikes are fitted with a inline filter anyway unlike older machines that relied on the tap filter only. [img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img] Re: Fuel tank tap - Fazerider - 13-07-18 There are two inline filters. There is an advantage in not having the filter on the tap anyway, you’ll gain access to about a litre of fuel that can’t otherwise be used. Re: Fuel tank tap - Trebus - 13-07-18 You can get rebuild kits for most taps too. Did an old XTZ750 that was leaking, 2 taps on those beats. I know you haven’t said it’s leaking but just in case. |
