Ivans - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Ivans (/showthread.php?tid=79810) |
Ivans - silverfz - 25-06-18 Hi At a quick glance how can you tell if you have ivanised carbs? regards Re: Ivans - 5LV - 25-06-18 Pop the carb top off and pull the slide out and check needle. Re: Ivans - Trebus - 25-06-18 I believe the springs are cut down which is another way to identify it. Re: Ivans - Falcon 269 - 26-06-18 Both correct, although clipping springs isn't specific to Ivan's kits. ![]() Stock needles are single taper and are stamped SD-129 or SD-130 around the top. Re: Ivans - silverfz - 26-06-18 Thanks, Mike you did mine years ago a banbury just was hoping for a quick check, got another fazer and it has an ivans sticker but gues i gotta have a look in to see if it been done, you dont keep reg numbers of the ones you've done do you? Re: Ivans - Falcon 269 - 29-06-18 Sadly, no on the reg numbers. Never thought I would do that many when I started ... ![]() If you have name of previous owner, PM me and I'll check my records when I get home in a week or so. Mike Re: Ivans - silverfz - 29-06-18 No worries Mike enjoy your hols |
