Naked Fazers!! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Naked Fazers!! (/showthread.php?tid=79809) |
Naked Fazers!! - chunk166 - 25-06-18 Hi. For you that have gone naked on your bikes, is it possible for you to post pics on this thread as to what your bikes look like! I am really having a problem in what lights i want to put on my bike as i can't afford a new fairing & most that i have seen on Ebay are either crap or overpriced!!
Re: Naked Fazers!! - celticdog - 27-06-18 Hi Fella, just try a google image search there's lots out there to get inspiration from. Re: Naked Fazers!! - chunk166 - 27-06-18 Cheers, I have had a look on google but some of the images when zoomed in on become blurry, i was hoping for some clearer pictures. :photo Re: Naked Fazers!! - Farmboy81 - 27-06-18 I'd been thinking of going the naked route too. The problem I had with google images was that after the first few a lot of them weren't even fazers; still useful for headlight and style ideas, but not so much when it comes to remounting clocks etc. Re: Naked Fazers!! - chunk166 - 28-06-18 To mount the clocks i was going to use headlight brackets with a small 90 degree/elbow bracket. Or use the existing fairing stay but modify it some how to take twin lights!!! :rolleyes :rolleyes :rolleyes Re: Naked Fazers!! - Paul - 25-07-18 Front End pics attached Headlight is off a RD350LC Re: Naked Fazers!! - F4celess - 15-08-18 This is a common question. You might want to search for similar threads that had alot of responses. ![]() You could possibly cut down the original front Fairing cage, so there's just enough left to mount your original Clocks, plus adapt for a new Headlight. There's SO MANY aftermarket motorcycle headlights on ebay / amazon etc. You'd usually pickup some generic Fork clamps to hold the Headlight in place, one each side (for a side mounted headlight). Aftermarket Speedo's too, usually come with a 'universal' clamp to attach to your Handlebar. So no problem there either.
Re: Naked Fazers!! - reaper1064 - 18-08-18 I have picked up a double headlight kit from Germany, not cheep, but it is well made and comes with a mounting bracket for the clocks and all the fittings. Re: Naked Fazers!! - Riggerlee88 - 08-09-18 Hi mate do you have a link for the twin headlight you purchased? Cheers Re: Naked Fazers!! - reaper1064 - 09-09-18 https://www.ebay.co.uk/itm/Double-Headlight-for-Yamaha-FZS-600-Fazer-Doppelscheinwerferanlage-Chrome/263751066230?hash=item3d68c9e276:g:3RkAAOSwAj5ZwNU~ Here you go mate. Re: Naked Fazers!! - Riggerlee88 - 10-09-18 awesome cheers
Re: Naked Fazers!! - F4celess - 10-09-18 That specific item is called dominator headlights with the characteristic bug eye style. You will find a lot of variations if you search the above phrase in ebay, amazon etc. Edit: Didn't see at first, that specific Kit above includes extra brackets to mount original FZS600 Speedo. Neat touch if you wanted to retain the bulky 1990's Analog dials. ![]() A lot of the Dominator headlight kits are just the 2 light units with fork mounting brackets. Universal fit. |
