Damper rod bolt - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Damper rod bolt (/showthread.php?tid=79808) |
Damper rod bolt - Dea-ville - 24-06-18 Hi all, planning to change the front springs soon on my gen 1 fazer thou, i know removal of the damper rod bolt is required when changing seals but is it required when changing the springs? Flicking through the Haynes manual it shows removal of spring & change of fork oil without touching the damper rod bolt. Re: Damper rod bolt - b1k3rdude - 25-06-18 (24-06-18, 01:57 PM)Dea-ville link Wrote:
Re: Damper rod bolt - Dea-ville - 26-06-18 Thank's bud, looking at the service history the seals have recently been done so i'm looking to change the oil & springs. Never seen a seal "puller" before, have you used one? easy to use? Re: Damper rod bolt - BBROWN1664 - 26-06-18
Re: Damper rod bolt - 5LV - 27-06-18 Springs come out seperately. If you're REALLY good you don't need to drop the forks out. Re: Damper rod bolt - b1k3rdude - 27-06-18 (26-06-18, 07:41 AM)Dea-ville link Wrote: Thank's bud, looking at the service history the seals have recently been done so i'm looking to change the oil & springs. Never seen a seal "puller" before, have you used one? easy to use?I've seen it done in person, the mechanic made a semi-circular cover out of thick plastic for the top of the fork to protect it from the tool - then hooked the took into the seal and levered it straight out. (26-06-18, 12:28 PM)BBROWN1664 link Wrote: You do have to turn the whole bike upside down to drain the oil though :pokefunEr read do you need glasses? read my post again - removing the adjuster from the fork tube drains the oil, then just flush the tube with fresh oil. |
