a different kind of EXUP problem - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: a different kind of EXUP problem (/showthread.php?tid=79775) |
a different kind of EXUP problem - red98 - 12-06-18 The mighty thou has had a bit of a lumpy tickover recently , iam planning to ride down to poole bike night this evening so with that in mind I got up early with the intention of balancing the carbs , started the bike up to get it up to temperature and I get the 7000 rpm code , exup , not serviced for I while so I strip it down to find the cable holding /guide bracket has rusted through :eek managed to weld It up although not the best job it has made the bike useable , anyone else had this problem or is it my lazy maintenance :o Re: a different kind of EXUP problem - Hugh Mungus - 12-06-18 Mine was worse than that. At least you had something to weld to. Given the exposed position it's not really surprising that they rot. Re: a different kind of EXUP problem - Dustydes - 19-06-18 Yep mine was in 2 bits. Fing hard to find one, new were out of stock. Also cam wheel had rusted away, new one was from Fowlers. And cable was fooked so made new. |
