Dodgy inicator - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Dodgy inicator (/showthread.php?tid=79689) |
Dodgy inicator - Valley boi - 18-05-18 My nearside indicators flash very fast now and again but not all the time they are not led bulbs. And the offside are fine any ideas would be great as I've got mot soon. Re: Dodgy inicator - redmandan - 18-05-18 Have you tried switching a few bulbs around from the side that works to the side that doesn't? Maybe it's as simple as one bulb being a bit dodgy. Re: Dodgy inicator - darrsi - 19-05-18 Quicker flashing is normally a bulb out somewhere. Re: Dodgy inicator - tommyardin - 19-05-18 could also be a bad earth on the indicators Re: Dodgy inicator - daviee - 19-05-18 check all connections as tommy said more than likely a bad earth Re: Dodgy inicator - Bretty - 19-05-18 My indicators are a bit temperamental. Previous owner fitted some dodgy aftermarket ones to the front which let in water, corrode a bit and develop a bad connection. Cleaning the bulb connection and wd40 usually sorts mine. Writing is solid. Re: Dodgy inicator - darrsi - 19-05-18 (19-05-18, 07:03 AM)Bretty link Wrote: My indicators are a bit temperamental. Previous owner fitted some dodgy aftermarket ones to the front which let in water, corrode a bit and develop a bad connection. Cleaning the bulb connection and wd40 usually sorts mine. Writing is solid. Mine can be too........on...off...on...off...on...off...i need to get them sorted out really :lol Re: Dodgy inicator - BBROWN1664 - 19-05-18 If a bulb partially shorts out, so it still works, it can cause faster flashing as the resistance is lower. Try changing both bulbs. |
