borken caliper bleed nipple - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: borken caliper bleed nipple (/showthread.php?tid=79651) |
borken caliper bleed nipple - psyfi_1 - 08-05-18 broken caliper bleed nipple any suggestions Re: borken caliper bleed nipple - andybesy - 08-05-18 Has it sheared or just rounded? If it's sheared, is it flush? There're quite soft, so you may be able to hammer something like a star drive bit in to it, then turn it using that? Probably best to remove the caliper from the bike first. A picture would be useful. Andy Re: borken caliper bleed nipple - andybesy - 08-05-18 Also, was it sheared due to not wanting to come undone, or over-tightening? If it's just been over tightened then it should come out okay if you can only get a grip on it, but if it sheared when you tried to undo it then presumably it's corroded in there, which can be harder. Re: borken caliper bleed nipple - psyfi_1 - 08-05-18 no its sheared flat to the caliper............ sucks balls Re: borken caliper bleed nipple - BBROWN1664 - 08-05-18 get a small ez-out and wind it in gently. The nipple should come out. Re: borken caliper bleed nipple - psyfi_1 - 08-05-18 okay i will buy one tonight and try it out......... Re: borken caliper bleed nipple - daviee - 08-05-18 you can get away with out it so wouldnt worry to much about it worst case buy a banjo bolt with a bleed nipple on it Re: borken caliper bleed nipple - Trebus - 08-05-18 For next time, a bit of heat can help wonders. And some alu anti seize paste smeared on the threads will stop them getting stuck. I find car rear slave cylinders to be the worst for it but again, heat normally helps shift them. Re: borken caliper bleed nipple - psyfi_1 - 14-05-18 can you heli coil a caliper Re: borken caliper bleed nipple - Gnasher - 15-05-18 Did it snap off because of something you did of was it like that when you got the bike? Re: borken caliper bleed nipple - psyfi_1 - 26-05-18 it snapped i turn it a bit to forcefully like a tit Re: borken caliper bleed nipple - Gnasher - 26-05-18 Was you doing it up or undoing it? Re: borken caliper bleed nipple - psyfi_1 - 26-05-18 undoing Re: borken caliper bleed nipple - Gnasher - 26-05-18 (26-05-18, 02:28 PM)psyfi_1 link Wrote: undoing Ok it's very likely the nipple was over tightened by whomever work on the caliper before you. As mentioned above an ez out will normally work, when I've done them I use a bit of heat on the caliper body around the nipple just a butane gas torch for a about 30 seconds and out they come. You only need 6Nm or 4.5 Ft- lbs. |
