sump plug cock up. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: sump plug cock up. (/showthread.php?tid=79647) |
sump plug cock up. - Ricky - 07-05-18 Hi ,changed my oil last year for the first time on the FZS 1000 my self, decided to use a after market off EBay magnetic sump plug . The threads on the plug are not as long as standard plug, and when I changed my oil this morning I have found that it has ripped out the first few threads in the sump and obviously my old plug will now not start because of damaged threads!!!! What the he'll do I do now? Any ideas? What is the size of the plug? Can I retap as there are still plenty of threads left? What size tap would I need? The bike is in my garage so it is stuck there. Any help or advice would be gratefully received, thanks. Re: sump plug cock up. - Ricky - 07-05-18 Looking like the size of the plug is M14x1.5mm ,so if I buy a tapir tap I might have a go? Or does any one have a better idea ? Re: sump plug cock up. - NorthWestern - 07-05-18 You can try the tap, it won't "repair" the threads though, just clean them up so your bolt can pass through to the undamaged ones. You will still only have a small number of threads holding on, might be OK... Other than that it's a helicoil or new case. Re: sump plug cock up. - Ricky - 07-05-18 I think about 70% of the threads are still there and obviously the first bit will be damaged, the EBay plug is half the size of original so hopefully I might have a chance, just so annoyed for using crap plug. Re: sump plug cock up. - Trebus - 07-05-18 You could use a tapered plug or worst case you might need a helicoil repair Re: sump plug cock up. - Mustang - 08-05-18 You can buy sump plug repair kits, you get a tap and 6 plugs and washers. They go up 1mm. Thing is you have to get the tap dead perpendicular to the hole or it won’t seal. Don’t ask me how I know! Re: sump plug cock up. - bludclot - 09-05-18 Decent quality rubber washers from a local plumbing merchant also work very well. Re: sump plug cock up. - Ricky - 09-05-18 Ordered a M14x1.5mm tap from EBay and will try to get the threads going, but if that does not work will go down the plug repair route. My mate a car mechanic say very common problem on vw cars as they have ally stumps and he has repaired many over the years and the plug is the same size. Re: sump plug cock up. - Hugh Mungus - 09-05-18 I've used dowty washers instead of traditional sump plug washers. Like these on eBay 132585478534 check which size you need before ordering. Re: sump plug cock up. - Trebus - 09-05-18 (09-05-18, 12:15 PM)Hugh Mungus link Wrote: I've used dowty washers instead of traditional sump plug washers. Like these on eBay 132585478534 check which size you need before ordering. Agreed, these are good and reusable. Re: sump plug cock up. - Ricky - 13-05-18 I have now received the tap, £ 7 from EBay a tapir and plug tap so not bad.The taper tap fitted straight in and turned easily no problem, the original sump bolt with copper washer is now been fitted and all seems ok no leak, so hopefully I might have got away with it. Re: sump plug cock up. - sullspots - 13-05-18 (13-05-18, 08:53 PM)Ricky link Wrote: I have now received the tap, £ 7 from EBay a tapir and plug tap so not bad.The taper tap fitted straight in and turned easily no problem, the original sump bolt with copper washer is now been fitted and all seems ok no leak, so hopefully I might have got away with it. Good stuff,I've seen on another forum someone using plumbers tape to good effect on the sump plug if the thread was a bit ballsed up. Re: sump plug cock up. - tommyardin - 15-05-18 (13-05-18, 08:53 PM)Ricky link Wrote: I have now received the tap, £ 7 from EBay a tapir and plug tap so not bad.The taper tap fitted straight in and turned easily no problem, the original sump bolt with copper washer is now been fitted and all seems ok no leak, so hopefully I might have got away with it. Just go easy when tightening it, remember you are only tightening up on 70% thread, it would be easy to pull the thread in cast alloy. Great you have it sorted as it would be shame to have the bike in dry dock with this weather. |
