sorted she starts - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: sorted she starts (/showthread.php?tid=79641) |
sorted she starts - psyfi_1 - 05-05-18 so cleaned bowls out and blew all the jet holes clear and put everything back together set the pilot ifle screws to two turns and then rebuilt but now shes not starting she turns over but doesnt start and maybe third try in pops/ backfires Re: cleaned carbs now she wont start and kinda back fires - psyfi_1 - 05-05-18 though i dont know if i left it long enough for the float bowls to fill i will try again in a bit Re: sorted she starts - daviee - 05-05-18 the pump will only prime for 5 seconds when you switch it on so switch it on an off till the pump stops then you no the carbs are full Re: sorted she starts - psyfi_1 - 05-05-18 yeh had the coil leads swapped over.......... but cylinders three and four still arent firing....... :'( Re: sorted she starts - daviee - 05-05-18 what way have you got them plugged in Re: sorted she starts - psyfi_1 - 05-05-18 ht leads are set to 1-4 2-3 |
