carb diaphragm screws - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: carb diaphragm screws (/showthread.php?tid=79622) |
carb diaphragm screws - celticdog - 01-05-18 Hi Gents has anyone had any luck removing the black plastic vac chamber covers to access the diaphragms? Carb no 2 isn't sliding as well as I'd like, as usual they're the typical Yamaha cross-head screws made of cheese. Re: carb diaphragm screws - Disorderlypunk - 01-05-18 just give them a good dose of plusgas or similar long before you try to remove them half the problem isnt the screws its the screwdrivers used - they are J.I.S screws and not phillips like most people have J.I.S screwdrivers (japanese industrial standard) are not a common find in toolboxes although on my want list Re: carb diaphragm screws - robbo - 01-05-18 Vessel(one of Japans oldest tool manufacturers) Megadora, 3 piece J.I.S screwdriver set on Amazon £22.70. It's odd that Philips won't work on j.i.s. screws but the Vessel drivers work on Philips. All the small grub screws on Shimano pushbike gears, use these. Re: carb diaphragm screws - Disorderlypunk - 01-05-18 this is why [smg id=3146] [smg id=3147] Re: carb diaphragm screws - robbo - 01-05-18 All to do with the angle of the dangle :lol . Re: carb diaphragm screws - daviee - 01-05-18 small set of vice grips to crack them free first Re: carb diaphragm screws - tommyardin - 02-05-18 Expensive but good. https://www.amazon.co.uk/Hozan-JIS-5-Screwdriver-Gen-HOZAN/dp/B003F63WI8 Re: carb diaphragm screws - robbo - 02-05-18 Tom, You might get more screwdrivers in the Hozan set, but for quality those by Vessel are like chalk'n'cheese. There again it depends on how much use they'll get, a bit like B&Q's own make and Snap On for example. Handy to have in your toolbox either way. :thumbup Re: carb diaphragm screws - celticdog - 03-05-18 Thanks for all of help this guys! You're never to old to learn something new. I've an old under seat screwdriver from a Kawa from years ago I'm going to give it a try with this.( I don't have a Fazer set :\ ). I've ordered a set of Megadora, I've been struggling with jap crosshead screws on bikes for years! Re: carb diaphragm screws - Disorderlypunk - 03-05-18 i picked up a set of cheap hammer through screwdrivers on ebay (solid grey case, blue handles) about 12 of them and they are the closest i have found to work on bike screws but it was pure luck if im honest with ya. Re: carb diaphragm screws - His Dudeness - 03-05-18 The JIS screws have a small indent punched into the head so you can tell them apart from Phillips head. If you have the original tool kit that came with the bike there will be a JIS screwdriver in it ![]() Re: carb diaphragm screws - daviee - 03-05-18 (03-05-18, 03:30 PM)His Dudeness link Wrote: The JIS screws have a small indent punched into the head so you can tell them apart from Phillips head. If you have the original tool kit that came with the bike there will be a JIS screwdriver in it Re: carb diaphragm screws - tommyardin - 03-05-18 Heard great things about these bad boys so ordered some to give them try out. https://www.ebay.co.uk/itm/Laser-7036-4-Piece-JIS-Screwdriver-Set/142773399122?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Re: carb diaphragm screws - Jamieg285 - 17-05-18 I went for one of these. Nice and compact for storage, with JIS, Pozi and flat in the kit: https://www.amazon.co.uk/gp/product/B00E55DL4I/ Re: carb diaphragm screws - Bretty - 17-05-18 I have a set of screw driver bits. Has every Philips head you can think of. I'm pretty anal about getting the right size bot to match the screw. See if you can find a set like this but branded: https://www.amazon.co.uk/gp/aw/d/B000QB2XDK/ref=mp_s_a_1_3?ie=UTF8&qid=1526589717&sr=8-3&pi=AC_SX236_SY340_QL65&keywords=hex+screwdriver+bits&dpPl=1&dpID=51UJTyT0XWL&ref=plSrch Re: carb diaphragm screws - fazersharp - 19-05-18 I have the OEM tool kit and there is a handle that takes the shafts and there are two shafts 1 has a small JIS and a small flat head on the other end and the other has a large JIS and a large flat head. Stupid that I have never used them - thinking they were not as good as my own screwdrivers because the kit ones look cheap what an idiot I have been rounding off screwheads for 17 years owning the bike and I was only 2 feet away from the proper too all the time :wall |
