fazer 98 firing order - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: fazer 98 firing order (/showthread.php?tid=79576) |
fazer 98 firing order - psyfi_1 - 20-04-18 Hey can you guys tell me coil leads go ive noticed mine are set to 1-2-3-4 so left coil is firing 1-2 and right coil is firing 3-4 is this right i dont think it is but just checking Re: fazer 98 firing order - BBROWN1664 - 20-04-18 If I remember correctly. The firing order is 1-3-4-2 and the coil on the left should connect to #1 & #4 with the coil on the right to #2 & #3 Re: fazer 98 firing order - Bretty - 20-04-18 I thought it fired 1-2-4-3... but then perhaps I have the cams spinning the wrong way inside my head?! (the cams spin in the same direction as the wheels no? or the other way). :look Re: fazer 98 firing order - BBROWN1664 - 20-04-18 (20-04-18, 12:54 PM)Bretty link Wrote: I thought it fired 1-2-4-3... but then perhaps I have the cams spinning the wrong way inside my head?! (the cams spin in the same direction as the wheels no? or the other way). 1-2-4-3 or 1-3-4-2 doesn't make much difference really. the important part id that 1 & 4 are on the same coil and 2 & 3 are on the same coil. |
