various bearing sizes - add what you know - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: various bearing sizes - add what you know (/showthread.php?tid=79536) |
various bearing sizes - add what you know - Disorderlypunk - 15-04-18 ok so after a post last week and my bearing issues i thought i would start a ongoing link of bearing sizes please only post actual sizes no jokes etc unless you KNOW a post is inaccurate please add the year of your bike as although it is likely the same a quick check through fowlers will tell you if its the same part code - i am a big fan of SKF bearings and would advise that is the route to go "2000 5dm7" Rear wheel bearings - 6204 2RS Sprocket carrier bearing - 6206 2RS - mine had a 6206RS which is only one seal and it truely shit the bed Re: various bearing sizes - add what you know - celticdog - 16-04-18 1999 5DM4 front wheel 6203LLU/2A (17x40x12)mm rear wheel 6204 2RS (20x47x14)mm clutch hub bearing 62062RS (30x62x16)mm Clutch hub oil seal MHSA-40-62-8-B I'm a fan of FAG bearings, mainly because my local bearings factor is a dealer/stockist. Re: various bearing sizes - add what you know - tommyardin - 16-04-18 (16-04-18, 07:36 AM)celticdog link Wrote: 1999 5DM2 Skefco SKF for me every time. Re: various bearing sizes - add what you know - KardashianKim - 19-04-18 various bearing si Where do you |
