Lubed up. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Lubed up. (/showthread.php?tid=79497) |
Lubed up. - NorthWestern - 07-04-18 Not sure if it is nation wide but aldi are flogging wd40 brand chain lube and chain wax for a quid a tin. Re: Lubed up. - darrsi - 08-04-18 (07-04-18, 04:51 PM)NorthWestern link Wrote: Not sure if it is nation wide but aldi are flogging wd40 brand chain lube and chain wax for a quid a tin. I've used it before, comes in smaller cans and handy to have if the bike's been sitting all day in a massive downpour. Re: Lubed up. - Rungrawee - 18-04-18 I have the same idea as you. Re: Lubed up. - Millietant - 18-04-18 I've bought 3 of each (cleaner, lube and chain wax). Very handy size to carry around on the bike under the seat.
Re: Lubed up. - darrsi - 19-04-18 I generally always use Wurth lube, but every now and then i just use a paint brush with engine oil and soak the hell out of the chain with it. As it's so wet it gets everywhere inside the links instantly and it's really easily applied. Just make sure you put newspaper down once parked up, 'cos it will obviously drip for a day or two. Re: Lubed up. - Oldgit - 20-04-18 Just cover yourself in KY Jelly then your really lubed up. Re: Lubed up. - darrsi - 20-04-18 (20-04-18, 10:21 AM)Oldgit link Wrote: Just cover yourself in KY Jelly then your really lubed up. Have you ever spent a long time in prison perchance? :lol |
