Rear tyre balancing question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rear tyre balancing question (/showthread.php?tid=79435) |
Rear tyre balancing question - Nemesis - 24-03-18 Hey up Foccers, I put a new rear tyre on yesterday, when I asked about balancing he said I would need to strip brake disc and drive cog off first, is he speaking shit or am I worrying over nothing just a question for future reference as next time then I'll probably renew both items whilst all stripped. Re: Rear tyre balancing question - cl1ve2004 - 24-03-18 As long as the balancing dot on the new tyre is in line with the valve,balancing should be easy.. no need to remove anything.. Re: Rear tyre balancing question - vinnyb - 24-03-18 Has anyone seen or tried these? http://innovativebalancing.com/motorcycle.htm Re: Rear tyre balancing question - NorthWestern - 24-03-18 The "cog" (and carrier) just pulls off as it's only held in the wheel by the friction of the cush rubbers. It is always removed for balancing. I've never seen anyone remove a disk to balance a wheel... Re: Rear tyre balancing question - Nemesis - 24-03-18 Thanks guys appreciate all replies Re: Rear tyre balancing question - Mustang - 24-03-18 I leave my sprocket carrier and Cush drive on for balancing. Never had an imbalance Re: Rear tyre balancing question - unfazed - 25-03-18 (24-03-18, 05:34 PM)Nemesis link Wrote: Hey up Foccers, I put a new rear tyre on yesterday, when I asked about balancing he said I would need to strip brake disc and drive cog off first, is he speaking shit or am I worrying over nothing just a question for future reference as next time then I'll probably renew both items whilst all stripped. Balance the wheel as it will be on the bike. Re: Rear tyre balancing question - crussell92 - 25-03-18 I fit my tyres myself and never balance the wheels, never had any kind of balance problem on any bike thus far so if you find the same i wouldn't worry Re: Rear tyre balancing question - Nemesis - 25-03-18 Did 80 miles today including motorway speeds also 2 up. All seems well as you said
Re: Rear tyre balancing question - unfazed - 25-03-18 (25-03-18, 08:21 AM)crussell92 link Wrote: I fit my tyres myself and never balance the wheels, never had any kind of balance problem on any bike thus far so if you find the same i wouldn't worry You wont have problem, but watch the tyre wear, if tyres are not balanced you will see a part of the tyre wear quicker, this is usually the heaviest part of rim and tyre pairing. It is rare to get a tyre rim combination not requiring balancing after fitting, often the balance may only be out by 10-20grams and most will never notice an issue. However go over that and you will definitely feel it because an out of balance rim/tyre combination causes vibration. Each to his own, I also fit my own tyres and always balance front and rear. Re: Rear tyre balancing question - crussell92 - 27-03-18 Not that im trying to say you're wrong, but I can't see how balancing would make that much of a difference to the tyre wear. Logically if the wheel is vibrating as it's going round it's going to generate more heat and maybe wear out quicker? But if you feel your tyre after a ride in the summer i don't think it would make any noticeable difference. The only thing I could think of it affecting longer term is the wheel bearings as they vibrate on the axle. Re: Rear tyre balancing question - tommyardin - 27-03-18 Your wheels should be balanced with the brake discs in place, the wheel rotates with the discs on why would you remove them balance the wheel and then put discs back on for them to possibly put the wheel out of balance again. It is always recommended to balance wheels with new tyres, tyres can sometimes take up to 40 Grams to balance them, those sort of imbalances can cause the wheel to throw as that area hit the road at incredible speeds, causing a bumping feeling, wheel wobble, vibration, noise and tyre wear. I would hasten to add that funnily enough this was a conversation I had with the tyre fitter yesterday when I had a new Bridgestone T30 fitted to the front of my old girl. Alex and Darron are the guys (A-Force Motorcycles of Aldershot) that I trust to work on my bike, they are the experts, so I will take there wisdom onboard and always get my tyres balanced. It seems to me that taking the twin disks off you bike and balancing the wheel in some ways a bit like removing you air filter element, balancing and tweaking your carbs, then connecting up the air filter again. Re: Rear tyre balancing question - Nemesis - 27-03-18 It was the rear I was on about Tommy but logically I agree with you surely any wheel front or back should be balanced with all the tackle attached, I,'ll see how it goes for now and sort if any issues arise, but will balance rear next time. Re: Rear tyre balancing question - Gaz66 - 01-04-18 Yes, he's talking bollox. Everything that has mass & rotates will vibrate & needs balancing, you may be unable to detect it, but it will defo vibrate if not balanced. Personally I leave all components fitted (discs & sprocket carrier etc) achieves a better dynamic balance of all rotating parts, most tyre fitting places don't balance with sprocket carrier fitted tho. All depends on what equipment you're using to balance a wheel. ie) Electronic Dynamic balancer ie) Home DIY frame type balancer I fit & balance my own tyres & use lead bike specific weights, I have access to both types of blancers but prefer the frame type for bike wheels. I'd never allow a tyre fitter to balance my wheels, they don't seem to give a shit about how they remove old balance weights or consider where they slap on on fugly balance weights... But then I'm OCD as F***K. Re: Rear tyre balancing question - unfazed - 01-04-18 :agree Re: Rear tyre balancing question - Dudeofrude - 03-04-18 (01-04-18, 09:55 AM)Gaz66 link Wrote: Yes, he's talking bollox. Yeah I was gutted about this myself. I have lovely gold powdercoated wheels and they go and stick two fugly lumps of grey metal on them, could have at least asked me first. I know its superficial but you'd think they'd do coloured ones by now haha Re: Rear tyre balancing question - unfazed - 03-04-18 They do them in 2 colours Black or Silver, you painted your wheels the wrong colour :lol Re: Rear tyre balancing question - slimwilly - 11-04-18 I test my rear wheel on the bike, put it up on paddock stand and run it through the gears up to high revs,,,it does not jump or vibrate,,good enough so far |
