Power commander 3 not working - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Power commander 3 not working (/showthread.php?tid=79404) |
Power commander 3 not working - Mustang - 15-03-18 does anyone on here have any experience with these? Just got one for my FZ1, connected up to laptop to check what map was in it but won’t communicate as it needs external power. so I took sellers word that the map is off a FZ1 and an Akro can, can’t do any harm . Wired it up to the bike and fitted the o2 eliminator plug, bike won’t start. Just cranks, pc leds flash then go off. Tried to connect to the laptop with it on the bike, won’t communicate. Have connected 9v battery to pc3 and tried to communicate with laptop, no deal. Am at al loss really as it’s plug n play and the seller assures me it was fully working. Seller is from Stoke way so fairly local, I’ve asked him if he can help. In the meantime can anyone else help? Re: Power commander 3 not working - Dudeofrude - 15-03-18 Definately something wrong. Mine worked straight away with no issues. Sorry I cant be of any help but I would try for a return and refund ? Re: Power commander 3 not working - Mustang - 16-03-18 Guy I got it off is decent and will accept it back, just don’t work Re: Power commander 3 not working - slappy - 16-03-18 Have you connected the earth wire and got a good earth? Check the the connector between the bikes loom and the power commander, mine were quite hard to get fully seated together correctly. Also I have heard that the 9V battery needs to be new for it to give the necessary voltage. Re: Power commander 3 not working - Mustang - 16-03-18 (16-03-18, 05:11 PM)slappy link Wrote: Have you connected the earth wire and got a good earth?Done all that, new 9.56 v battery.....pc lights stay on ok, usb plugs in and pings on the laptop but no comms. Re: Power commander 3 not working - PieEater - 18-03-18 From a computer perspective you will need to make sure that you have the correct software installed on your laptop in order for it to communicate properly. There are a few different versions of the software depending on the version of the power commander that you have. So I would go back to the PC website and make sure that you have the correct software and download the correct instruction manual and follow the instructions. Re: Power commander 3 not working - Mustang - 18-03-18 I used the latest software, from the site as the pc didn’t come with a disc. Used a ubs lead - they are all the same aren’t they? What I can’t find out is what the firmware is in the pc, cos I can’t talk to it! I said to the seller, even if it worked on the bike, I’d need to change the map if I wanted a custom one or if it was sold on and used on an R1 or something, so it’s no good to me. Re: Power commander 3 not working - Rob - 18-03-18 was it the 3 software and not the 5 ? http://www.powercommander.com/powercommander/downloads/powercommander_downloads.aspx?ProdType=PCIIIUSB download the firmware then the maps choose a map then connect to power commander and press install. give it a go what you got to lose ? i had a disc but used same procedure Re: Power commander 3 not working - Mustang - 18-03-18 (18-03-18, 03:22 PM)Rob link Wrote: was it the 3 software and not the 5 ? http://www.powercommander.com/powercommander/downloads/powercommander_downloads.aspx?ProdType=PCIIIUSB download the firmware then the maps choose a map then connect to power commander and press install. give it a go what you got to lose ? i had a disc but used same procedure It’s a pciii usb. The software will not ‘see’ the pc. Even the pcprog software to update the firmware won’t see it. I’ve read that the pc can become locked and needs to be reset somehow by dynojet. I’m sending it back for refund so if anyone has one for sale let me know Re: Power commander 3 not working - Dudeofrude - 18-03-18 Having searched the net a bit it seems to be a very common problem and is down to a firmware error on the pc3. Its possible to fix a home if your savvy with a computer. It involves wiping then re flashing the pc3 with the latest firmware. There are guides online but just depends if you want to give it a go Re: Power commander 3 not working - Mustang - 20-03-18 (18-03-18, 11:00 PM)Dudeofrude link Wrote: Having searched the net a bit it seems to be a very common problem and is down to a firmware error on the pc3. Its possible to fix a home if your savvy with a computer. It’s gone back now. Snapped an exhaust stud off now. Re: Power commander 3 not working - Dudeofrude - 20-03-18 All sunshine and rainbows for you this week then ? Re: Power commander 3 not working - Mustang - 21-03-18 (20-03-18, 07:44 PM)Dudeofrude link Wrote: All sunshine and rainbows for you this week then ? Just have to use the Gen 1 instead |
