Oil Filter Wrench - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Oil Filter Wrench (/showthread.php?tid=79391) |
Oil Filter Wrench - MikeBike - 10-03-18 Hello Guys. I´ve bought a used FZS 600 1998-1999. No tool kit was on the bike. I wish to buy an oil filter wrench. There are some universal on ebay or amazon but I am not sure if they work. Can you suggest me one and also tell me if you know, what´s the diameter for the filter? I ve seen a cheap one that is for 65mm diameter filter. Is it the filter this size? Thanks Miguel Re: Oil Filter Wrench - steve 10562cc - 10-03-18 Wemoto do a oil filter wrench for your bike £4.52 If you've never used I have found them good to use with quick delivery, though other people I know have not been so complimentary. Re: Oil Filter Wrench - fazersharp - 10-03-18 I use the type that is a cap which fits over the filter and has a socket wrench hole in the top and then thread a short socket extension bar through the downpipes to get on to it. Re: Oil Filter Wrench - Fazerider - 10-03-18 No extra tools are needed, just place a sharp screwdriver at the edge of the filter and tap it round with a hammer. In a couple of seconds it’s rotated far enough to undo it the rest of the way by hand.
Re: Oil Filter Wrench - fazersharp - 10-03-18 What gets me is what law of physics dictate that you do up an oil filter by hand and it tightens its self up and yet you tighten a nut by hand and it will fall off within a day Re: Oil Filter Wrench - VNA - 10-03-18 http://www.wemoto.com/bikes/yamaha/fzs_600_fazer/98-99/picture/oil_filter_wrench_for_hiflo_filter/ Re: Oil Filter Wrench - tommyardin - 10-03-18 (10-03-18, 12:52 PM)fazersharp link Wrote: What gets me is what law of physics dictate that you do up an oil filter by hand and it tightens its self up and yet you tighten a nut by hand and it will fall off within a day Ahh! So true Sharpie, but, if you put a small rubber O ring under the nut then nip it up tight with your fingers Hey presto the little blighter stays in place especially if you make the O ring moist with a little oil. But have to agree the cup type oil filter remover are the best I have used, 1/2" socket extension bar fits nicely between the headers. I have bought and tried strap, chain, C jawed pliers types, I have even reverted to driving a massive great pound through screwdriver right through the filter and used the screwdriver as a tommy bar to remove filters on different vehicle in the past (last method = last resort) but that is messy and should you find that the idiot down at the Motorfactors has given you the wrong filter you focc-d your not going anywhere in or on you steed. Re: Oil Filter Wrench - mtread - 11-03-18 Be aware that there are 2 sizes of cup filter wrenches for different width oil filters. Make sure you get the right one. Re: Oil Filter Wrench - darrsi - 11-03-18 Always nip up my oil filter by hand with a smearing of oil, but as said over time they do tend to really tighten up. Bought myself a 'heavy duty' chain wrench, probably overkill but WILL work and they're cheap too. Not used it yet, but a proper bit of kit when it matters. Re: Oil Filter Wrench - celticdog - 11-03-18 I've got one of these but it's a pain in the ars* to use on the bike because of the limited access from the exhaust down pipes. It still does the job though. Re: Oil Filter Wrench - darrsi - 11-03-18 (11-03-18, 09:29 AM)celticdog link Wrote: I've got one of these but it's a pain in the ars* to use on the bike because of the limited access from the exhaust down pipes. That's the type i normally used, and although works well it can be fiddly, so i thought i'd try this one as it was so cheap. https://www.amazon.co.uk/US-PRO-Filter-Wrench-diameter/dp/B0791GKFRP/ref=sr_1_5?ie=UTF8&qid=1520760914&sr=8-5&keywords=heavy+duty+oil+filter+socket+chain+wrench Re: Oil Filter Wrench - mtread - 12-03-18 That's why the 'cup' wrenches are so easy to use. Pop it on the filter and socket spanner with short extension bar between the middle two pipes. Simple. Re: Oil Filter Wrench - robbo - 12-03-18 What mtread just said :thumbup . Re: Oil Filter Wrench - Jamieg285 - 12-03-18 I use one of these: http://www.halfords.com/workshop-tools/tools/hand-tools/halfords-advanced-adjustable-oil-filter-remover Re: Oil Filter Wrench - darrsi - 12-03-18 Only £7.20 for the chain though
Re: Oil Filter Wrench - mtread - 13-03-18 + the cost of sticking plasters on your knuckles every time you use it :-) Re: Oil Filter Wrench - Slaninar - 13-03-18 Got this cheap one - works fine. ![]() So did a screwdriver - just punch through a filter and use it as a lever. The one Darrsi linked looks very nice and practical for most filters - including Fazer's. Re: Oil Filter Wrench - darrsi - 13-03-18 (13-03-18, 12:25 AM)mtread link Wrote: + the cost of sticking plasters on your knuckles every time you use it :-) Noooo? A ratchet with an extension bar should keep your knuckles intact no problem. |
