Plastic push rivets - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Plastic push rivets (/showthread.php?tid=79364) |
Plastic push rivets - Stevejay69 - 05-03-18 Which size push rivets are used to hold in the panel that goes around the seat, both mine are missing ? Re: Plastic push rivets - unfazed - 05-03-18 Use a screw centre or push centre one, you will find them in Halfords or any good motor factors. Standard one does not have a screw centre but the screw or push centre is easier to remove. Screw type pictured [img alt=https://images-na.ssl-images-amazon.com/images/I/41kB%2BklLjhL._SL500_AC_SS350_.jpg]https://images-na.ssl-images-amazon.com/images/I/41kB%2BklLjhL._SL500_AC_SS350_.jpg[/img] Re: Plastic push rivets - Stevejay69 - 05-03-18 Yeah they’re the ones but I’ve seen 2 different sizes for sale 6mm and 8mm Re: Plastic push rivets - unfazed - 05-03-18 Good question, I have packets of them in the garage because they are used in cars also, but never checked the sizes. Check it with a bolt to see what size goes in and buy accordingly :thumbup Re: Plastic push rivets - Stevejay69 - 05-03-18 I’ll do that but just thought someone might know of the top of their head Re: Plastic push rivets - Jules-C - 06-03-18 Hole diameter must be more then 6mm Re: Plastic push rivets - Stevejay69 - 06-03-18 I have bought both sizes, only pence, I’ll let you know when they arrive Re: Plastic push rivets - celticdog - 06-03-18 Hi these are the ones I got for doing the black infill panels on the front fairing, they're a good match to the originals. https://www.ebay.co.uk/itm/10x-6mm-Hole-Plastic-Rivet-Trim-Panel-Retainer-Clips-/280643592135?hash=item4157a95fc7:m:mSKNmn9d37rsO5_rpiHu9ug Re: Plastic push rivets - Stevejay69 - 06-03-18 They are the ones I ordered thank you everyone ? |
