Headlight unit swap - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Headlight unit swap (/showthread.php?tid=79359) |
Headlight unit swap - Clampy - 04-03-18 As spring slowly approaches I’m looking to swap my FZS600 headlights (with burnt-out reflectors) with one from the FZS400. It came from eBay with its wiring that connected to its original harness. The question is, will I be able to ‘plug’ them straight in, or would I be best doing the headlight mod to get both dipped beams on together? Any advice would be much appreciated. :rolleyes Re: Headlight unit swap - kgjersda - 10-03-18 I have done this swap and I would recommend adding a new wiring with relays for the lights. That way you get two main lights and two high beams!
Re: Headlight unit swap - daviee - 10-03-18 you will need to do the head light mod its not a hard job to do plenty of info on how to do it on this site |
