Starting circuit cutoff relay - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Starting circuit cutoff relay (/showthread.php?tid=79308) |
Starting circuit cutoff relay - PhilipM - 17-02-18 Hello, I joined this online club (I also joing the other one I'm afraid as well!) because I recently purchased an unfinished Malone F1000 that has a 2002 Yamaha Fazer engine installed. This is my first post and relates to the issue of integrating a motorcycle wiring loom with the separate demands of a made to measure car loom. Once finished I won't have the Fazer instruments nor the handlebar switches, headlamp looms and main key. Also because of the nature of the vehicle I don't want any circuits like sidestand, lean or clutch switches. It would certainly make the wiring easier and simpler if it was possible to eliminate the Starting Circuit Cutoff Relay, though looking at the wiring diagram this seems difficult. A Google search reveals a few people who have given it a go, but then given up. By any chance has anyone on here needed or wanted to remove theirs? Cheers Philip Re: Starting circuit cutoff relay - unfazed - 17-02-18 Bypassing the Starter Cut Relay is relatively easy, but for the rest much depends on what part of the wiring loom you are keeping or removing as some items are integrated into the Ignitor for example are you keeping: 1 The Fazer carbs 2 The Fazer starter circuit excluding the Starter cut out relay 3 The Fazer Fuel pump 4 The EXUP valve Re: Starting circuit cutoff relay - PhilipM - 17-02-18 Thanks for your reply and in answer to your questions 1) Yes, keeping Fazer carbs 2) Yes, using Fazer starter relay though having to replace handlebar push to start button with stand alone push button for starter 3) No, have a different fuel pump independently wired 4) Custom made exhaust manifold so no EXUP but am fitting an EXUP eliminator into the Yamaha harness plug Cheers Philip Re: Starting circuit cutoff relay - unfazed - 17-02-18 Philip Pm me your email address Re: Starting circuit cutoff relay - PhilipM - 18-02-18 Thanks and sent. Philip Re: Starting circuit cutoff relay - Gramaha - 13-09-19 Hi guys, I'm keen to know how to remove the circuit also. I'm restoring a poorly 99 fzs600 who's loom has been attacked in the past so I thought it easier to do away with. Any help appreciated. Re: Starting circuit cutoff relay - unfazed - 13-09-19 Easy enough to do, but would not recommend it.Why not buy a good loom off ebay Re: Starting circuit cutoff relay - Gramaha - 25-09-19 I did just that as a backup ?? I'm think I'm going to persist a bit longer with the old loom though to see if I can lose some more wires and fit it all in a custom battery/wiring box. It's had the air box and all clocks removed just has a GPS speedo. |
