cut genny cable - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: cut genny cable (/showthread.php?tid=79277) |
cut genny cable - bingo600 - 08-02-18 Alright guys, Iv'e had a little mishap and managed to cut the side of my generator cable, ive cut through 2 white wires and cut into blue a little. there looks to be 3 white 1 yellow and 1 blue Just wondering if these white cables do the same thing, can i just solder them back up? Re: cut genny cable - Trebus - 08-02-18 Usually that would be the 3 windings of the alternator and they are interchangeable. You should therefore be able to solder them up no problem. Normally white wires on a Yam, Honda use yellow as a rule. Re: cut genny cable - Disorderlypunk - 08-02-18 the yellow and blue should be your pick up coil wires so definatly repair the blue one if you exposed any bare wire Re: cut genny cable - bingo600 - 08-02-18 thanks guys il give it bash, i dont suppose it would cause any damage if it doesnt work.. Thanks |
