rear brake light?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: rear brake light?? (/showthread.php?tid=79216) |
rear brake light?? - johnakay - 22-01-18 what do you call these things that are fitted to top box's. I know it sound obvious but cannot find any on ebay using that. what I'm after is a rear light that has a brake light inc. I can find one of each but not 2 together. going touring in may so buying a bigger top box and I want the above fitted inside the red reflector. probably might be best having separate lights . what I would like is for them to be inside the red reflector that you got on the topbox. Re: rear brake light?? - johnakay - 22-01-18 found these so I'm sorted. dont know how to delete thabove post. https://www.ebay.co.uk/itm/Flexible-Motorcycle-48LED-Strip-Light-Rear-Tail-Turn-Signal-Indicator-Brake-Lamp/253215795446?epid=25006846059&hash=item3af4d668f6:g:I7IAAOSwry1Z6HgY Re: rear brake light?? - Fazerider - 22-01-18 It would be a pedantic MOT tester who fails it, but aren't indicators supposed to be at least 100mm from the tail/stop light? Re: rear brake light?? - robbo - 22-01-18 If you haven't bought your topbox yet, why not get the givi model with the built in brake light. It could be the 52litre Maxia. Re: rear brake light?? - johnakay - 22-01-18 givi to expensive. wont be using the indicators so it wont affect the mot when its due in 2019. . Re: rear brake light?? - Hugh Mungus - 22-01-18 I've bought a couple of those integrated LED units but haven't got around to fitting them yet. I was planning to stick one to the top of the number plate as I already have a Givi brake light in my top-box. |
