Clutch cable - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Clutch cable (/showthread.php?tid=79187) |
Clutch cable - robbie221282 - 12-01-18 Hi folks I’m about to venture on fitting a new clutch cable on my FZS600 I’m just wondering if anyone has done this and if so will I need to go get more engine oil or is the cable side of the bike dry . Would appreciate hints and tips . Thanks Re: Clutch cable - matt7chunk - 12-01-18 All dry under there mate , just remove the front sprocket cover and all will become clear , you may have to give the inside of the cover a good clean first to see the cable connection. Re: Clutch cable - darrsi - 12-01-18 It's all dry, although i'd advise a good pair of rubber gloves 'cos there's a good chance you'll encounter a mountain of oily crud when you take the side cover off. Re: Clutch cable - darrsi - 12-01-18 http://foc-u.co.uk/index.php/topic,10124.msg105459.html#msg105459 |
