fazer 600 1998 small hole in exhast pipe is it drain hole ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: fazer 600 1998 small hole in exhast pipe is it drain hole ? (/showthread.php?tid=79182) |
fazer 600 1998 small hole in exhast pipe is it drain hole ? - russprice - 10-01-18 hi all ive just bought a fazer 600 1998 model and noticed that there was a hole in underside of the exhaust between the hanger bracket and the link pipe to end can . i filled this as i thought it was a rot hole now the link pipe joint is blowing and passing condensation, was the hole i filled a condensation hole and supposed to be there ? should i redrill it think it was about 2 mm and thinking about it looked to round to be rot :S any help would be appreciated thx russ Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - Disorderlypunk - 10-01-18 yep its a condensation relief hole - i thought the same thing at first as it was blowing like mad - but that was because the exhaust was f##ked Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - russprice - 10-01-18 thx ill redrill it !! cheers Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - fazersharp - 10-01-18 Here you are it was discussed a while back too http://foc-u.co.uk/index.php/topic,15938.25.html Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - russprice - 10-01-18 thx anybody know what size the drain hole should be cant make my mind up weather to drill a 2 or 3mm hole back in place cheers Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - fazersharp - 10-01-18 (10-01-18, 07:07 PM)russprice link Wrote: thx anybody know what size the drain hole should be cant make my mind up weather to drill a 2 or 3mm hole back in place cheersYeh it should be the same size as it was before you filled it in :pokefun Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - russprice - 10-01-18 doh - lol :'( Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - Disorderlypunk - 10-01-18 5mm should do the job as the mrs says its not the size that matters - its how good a job it does Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - russprice - 10-01-18 lol :rollin cheers Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - tommyardin - 11-01-18 (10-01-18, 08:28 PM)Disorderlypunk link Wrote: 5mm should do the job That's not what she said to me :eek Re: fazer 600 1998 small hole in exhast pipe is it drain hole ? - Disorderlypunk - 11-01-18 (11-01-18, 12:24 AM)tommyardin link Wrote: [quote author=Disorderlypunk link=topic=23651.msg273702#msg273702 date=1515612528] That's not what she said to me :eek [/quote] nope i saw the video - wasnt it 'its not the size that matters but at least learn to use it' :lol :rollin |
