Ceiling Light Shade Removal Question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Ceiling Light Shade Removal Question (/showthread.php?tid=79148) |
Ceiling Light Shade Removal Question - YamFazFan - 03-01-18 Any info here would be much appreciated. Does anyone know how you remove the shade from the type of ceiling light in the photo please?. There's no outer shade fixings at all and no evidence of their ever having been any (no screw holes etc..) The shade will rotate endlessly both clockwise and anticlockwise without coming off. Both base and shade are plastic. Thanking you kindly ![]() Re: Ceiling Light Shade Removal Question - celticdog - 03-01-18 Well that's got me thinking! 1. try turning the white part anticlockwise but this time with downward pressure, it may need to catch on the thread. 2. Do the same again only in the opposite direction. 3. stick a screwdriver in between the black and white sections and gently try to lever off. 4. Do the same as no 3 again but this time have 2 screwdrivers- on at 3 and one a 9 o clock. 5. try any or all of the above to the black section in case it's like a 'sealed unit' with a lid. 6. Take a hammer to the foccer and buy a new light fitting. Re: Ceiling Light Shade Removal Question - Mark YPVS - 03-01-18 If the black base is plastic it should lever off but use a electrically insulated screwdriver and isolate the light first :eek :eek :rollin Mark ![]() Re: Ceiling Light Shade Removal Question - celticdog - 03-01-18 (03-01-18, 08:28 PM)Mark YPVS link Wrote: If the black base is plastic it should lever off but use a electrically insulated screwdriver and isolate the light first :eek :eek :rollin That's no good is it!?! How can you see what to do without having the light on. :lol Re: Ceiling Light Shade Removal Question - Mark YPVS - 03-01-18 (03-01-18, 08:34 PM)celticdog link Wrote: [quote author=Mark YPVS link=topic=23617.msg273260#msg273260 date=1515007716] That's no good is it!?! How can you see what to do without having the light on. :lol [/quote] Hahahaha i hadn't thought of that :rollin :rollin Re: Ceiling Light Shade Removal Question - YamFazFan - 03-01-18 (03-01-18, 08:25 PM)celticdog link Wrote: 1. try turning the white part anticlockwise but this time with downward pressure, it may need to catch on the thread. That was my first thought but no luck there :\ Re: Ceiling Light Shade Removal Question - Frosties - 03-01-18 (03-01-18, 08:25 PM)celticdog link Wrote: Well that's got me thinking! 'Cos it's ugly as fook :lol :lol Re: Ceiling Light Shade Removal Question - Hugh Mungus - 03-01-18 I would assume that it clips into place OR it might have a couple of slots that need lining up before it can be lowered. I suggest that you try rotating the shade while feeling for a slight notchy feeling which might indicate a slot having just lined up, then carefully prise it off. When that fails just hit it with the aforementioned hammer and replace with a nice new LED unit. Re: Ceiling Light Shade Removal Question - agricola - 03-01-18 1 Try turning the black base, it may be screwed onto a holder 2 Look for timing marks on both the black and white sections, if there are, line them up and pull the two apart 3 Wrap the thing in cling film and tap the white glass with a hammer, the film should stop the glass splintering all ove rthe floor and into your eyes, then carefully remove the offending object Re: Ceiling Light Shade Removal Question - YamFazFan - 03-01-18 (03-01-18, 08:59 PM)Hugh Mungus link Wrote: I would assume that it clips into place OR it might have a couple of slots that need lining up before it can be lowered. Tried that too with no luck :\ ( feeling for notches/slots, not prising which I'm reluctant to do until I'm sure I won't break anything) And before anyone else mentions it again :lol, I can't take a hammer to the offending item as it's not mine. Re: Ceiling Light Shade Removal Question - Nemesis - 03-01-18 Hammer time :rollin regardless, oops accidentally of course Re: Ceiling Light Shade Removal Question - fazersharp - 03-01-18 Did you idiots not listen NO Hammer -------- He cant touch it. Let me explain https://www.youtube.com/watch?v=otCpCn0l4Wo&list=RDotCpCn0l4Wo&t=14 Re: Ceiling Light Shade Removal Question - Skippernick - 03-01-18 (03-01-18, 09:15 PM)YamFazFan link Wrote: [quote author=Hugh Mungus link=topic=23617.msg273266#msg273266 date=1515009549] Then its not your problem! Fixed that for you. Thank me later.[/quote] Re: Ceiling Light Shade Removal Question - YamFazFan - 04-01-18 Yeah ta for that :rolleyes :lol Forgot to mention, both the base and shade are plastic. Re: Ceiling Light Shade Removal Question - Hugh Mungus - 04-01-18 (03-01-18, 09:15 PM)YamFazFan link Wrote: I can't take a hammer to the offending item as it's not mine. (04-01-18, 12:07 AM)YamFazFan link Wrote: Forgot to mention, both the base and shade are plastic. Two vital bits of info there... I've had the same sort of problem many years ago and there were 2 or 3 tiny grub screws. If you cannot find a grub screw in the black part that may be holding the white part in then it's going to be a prise off job. Re: Ceiling Light Shade Removal Question - red98 - 04-01-18 Yep , if its made of plastic that is indeed a big clue , at first glance I was thinking glass.....my guess as its plastic is , its probably an inexpensive unit and just clipped together , I would start by running a blade between the two parts , if it is just push fit it wont take much to separate the two halves , will be light weight and wont need much to hold it together.....looks old too me so take it easy when levering , that plastic might have gone brittle with age.... Re: Ceiling Light Shade Removal Question - YamFazFan - 04-01-18 Cheers fellas, that sounds likely then. I've updated the original post to include the plastic info now. Would it still rotate as it does if it was indeed clipped together do you think?. Re: Ceiling Light Shade Removal Question - BBROWN1664 - 04-01-18 (04-01-18, 09:10 AM)YamFazFan link Wrote: Would it still rotate as it does if it was indeed clipped together do you think?. Yes It will either prise off or will need a hammer. Depending how old it is it may break anyway. Re: Ceiling Light Shade Removal Question - Oldgit - 04-01-18 Hammer time--you Can touch this Re: Ceiling Light Shade Removal Question - YamFazFan - 04-01-18 (04-01-18, 10:30 AM)BBROWN1664 link Wrote: [quote author=YamFazFan link=topic=23617.msg273284#msg273284 date=1515053453] Yes It will either prise off or will need a hammer. Depending how old it is it may break anyway. [/quote] Approx 30 years old I'm guessing. OK thanks to the famous Foccer Font Of Knowledge i now feel empowered?. Will report back in due course. (only seeking to gain access to the light bulb in order to replace). |
