bike mis-fire,rev counter stops working,lights dim then it all works again?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: bike mis-fire,rev counter stops working,lights dim then it all works again?? (/showthread.php?tid=79063) |
bike mis-fire,rev counter stops working,lights dim then it all works again?? - gosport paul - 30-11-17 Hi folks,I have a 600 fazer 2000my,has been fine ,then it started playing up,rev counter stop working,bike won't rev over 2000rpm,lights fade a bit,then comes back ok again,can do 10 miles no fault,or straight off the driveway,has anyone else had the same problem. I have tried wiggling the wires behind the battery,it seems to stop temporarily then plays up again,have cleaned all the connections,tested voltage when running ok at 13.8-14v,then drops to 12-12.5 when rev counter stops working,any ideas on the fault? Thanks Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - daviee - 30-11-17 bad connection somewhere you will just need to go through all connections could be a bad earth sounds like you reg could be on its way out if the voltage is dropping thats the first place i would check it has a block connector and can fur up and give intermittent charging Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - gosport paul - 30-11-17 thanks Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - darrsi - 30-11-17 I’ve got one of these on my bike, they’re a steal at that price. https://www.ebay.co.uk/itm/Regulator-Rectifier-Voltage-Fit-YYAMAHA-TDM850-XVZ1300-95-05-FZS600-98-03-2002/131919012179?hash=item1eb6fc6153:g:kZwAAOSw-itXvqzK Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - gosport paul - 30-11-17 cheers for the link,seems cheap
Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - Disorderlypunk - 30-11-17 sounds like something that hapened to my old honda turned out to be corroded battery terminals a quick clean and all ran well again (was thankfull as i was stuck in the middle of nowhere) Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - Fazerider - 30-11-17 (30-11-17, 07:17 PM)darrsi link Wrote: I’ve got one of these on my bike, they’re a steal at that price. I’d recommend contacting the supplier first to get the measurement of the cable on the reg/rect unit before buying. I got with one that had such a short cable it couldn’t be plugged in, despite it being advertised as suitable for the FZS600. Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - gosport paul - 30-11-17 ok thanks for that advice,i'll message them first Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - His Dudeness - 01-12-17 (30-11-17, 04:16 PM)gosport paul link Wrote: Hi folks,I have a 600 fazer 2000my,has been fine ,then it started playing up,rev counter stop working,bike won't rev over 2000rpm,lights fade a bit,then comes back ok again,can do 10 miles no fault,or straight off the driveway,has anyone else had the same problem. I only started getting into the electrical side of things recently so you might be better waiting for someone more experienced but I think the highlighted part of what you said is the important clue to your problem and you need to be 100% certain that what you said there is correct because if the bike is dropping down to battery voltage while it's running it means it must be losing the ability to generate it's own electricity supply so if I was you I'd be checking the stator and the regulator/rectifier. For the stator check for continuity between the three phases, check the phase resistances, check if any of the phases are shorting to ground and check the AC output when the bike is running also check it's wiring and connectors going up to the regular/rectifier. If the AC voltage is in spec then the regulator/rectifier is probably the culprit. Sometimes electrical problems only show up when things get hot which might explain why you're only having the problem sometimes so do your measurements when the bike's hot and cold. Have a look at these videos if you're not sure about how to do the stator tests. They sound complicated but they're easy to do and you don't have to fully understand them, just have to do them ! No longer available ! No longer available Have a look at page 8-26 of the workshop manual too. http://foc-u.co.uk/index.php?action=downloads;sa=view;down=8 Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - darrsi - 01-12-17 (30-11-17, 09:39 PM)Fazerider link Wrote: [quote author=darrsi link=topic=23532.msg271830#msg271830 date=1512065864] I’d recommend contacting the supplier first to get the measurement of the cable on the reg/rect unit before buying. I got with one that had such a short cable it couldn’t be plugged in, despite it being advertised as suitable for the FZS600. [/quote] I just checked and i bought it just over a year ago from the the same supplier so it should be okay. Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - unfazed - 01-12-17 (30-11-17, 04:16 PM)gosport paul link Wrote: Hi folks,I have a 600 fazer 2000my,has been fine ,then it started playing up,rev counter stop working,bike won't rev over 2000rpm,lights fade a bit,then comes back ok again,can do 10 miles no fault,or straight off the driveway,has anyone else had the same problem. As Daviee mentioned I would also think it is more or a bad connection as 13.8 to 14 is good and dropping to 12 to 12.5 would be normal if the engine dies, which from you post seems to be what is actually happening. the misfire is when it restarts with extra fuel having being dumped into the engine when it cuts out. I would suggest you check the connections in the black box under the tank. There is a red block connector in there with Red and( as far as I can remember) Brown/Blue wires, this is the main supply from the Ignition switch and can corrode and/or burn from arcing it will cause the problem you describe. Check that first before buying anything you may not need Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - tommyardin - 07-12-17 Don't you just love it when people come up with great ideas for sorting out stuff
Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - Disorderlypunk - 07-12-17 i find it brilliant how it instantly comes to buying a new part and not the free stuff first - its even possible to test the reg rec instead of just replacing it ooh it had a battery drop it must be the reg rec broken - NO because the chances are the test was done top side of the battery terminals so a voltage drop can show from a bad earth or positive connection due to corrosion, or a bad connection on the reg rec connections that a a quick pull apart and clean could sort in seconds maybe more people need to be skin flints first then waste money later lol Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - darrsi - 07-12-17 (07-12-17, 02:20 AM)Disorderlypunk link Wrote: i find it brilliant how it instantly comes to buying a new part and not the free stuff first - its even possible to test the reg rec instead of just replacing it My bike, along with the regulator, was 17yrs old, spending £12.99 on it is hardly wasting money was it? It's just replacing a very old part for a new one. And it is Christmas :lol Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - His Dudeness - 09-12-17 Anyone else hate it when the original poster doesn't update the thread? It's like reading a book and the last chapter is ripped out :lol Re: bike mis-fire,rev counter stops working,lights dim then it all works again?? - Disorderlypunk - 09-12-17 he has been pushing it home for the last 4 days - suddenly that long distance rideout was a bad idea |
