piston rings for Fazer 600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: piston rings for Fazer 600 (/showthread.php?tid=79024) |
piston rings for Fazer 600 - edclarke - 12-11-17 Hi I'm currently rebuilding a 2000 fazer 600 which has ring wear , and i'm struggling to find new piston rings on line , be grateful if anyone has any links or contacts for a uk supplier of new piston rings for the Fazer. many thanks in advance. Re: piston rings for Fazer 600 - slappy - 12-11-17 Try AJ Sutton https://www.ajsutton.co.uk/genuineparts/9656/3/yamaha-fzs600-fazer-2000/crankshaft-piston?uID=0 Re: piston rings for Fazer 600 - bandit - 12-11-17 Fowlers, https://www.fowlersparts.co.uk/parts/view/4JH-11603-00 Re: piston rings for Fazer 600 - edclarke - 13-11-17 Fantastic thanks very much for the replies . will try them both. Re: piston rings for Fazer 600 - redmandan - 13-11-17 Hey Ed, how's the build going? Out of interest how did you diagnose ring wear? Re: piston rings for Fazer 600 - daviee - 13-11-17 easiest way is to place the ring in the barrel and measure the gap you do this in two places one about a inch down from the top of the bore and second about an inch up from the bottom that way you can tell ring wear and bore wear Re: piston rings for Fazer 600 - redmandan - 13-11-17 That's what I expected, a full teardown head off job. I tried to test my compression with a kit I bought to test my Yanmar marine diesel. https://www.amazon.co.uk/gp/aw/d/B00KCLSSVK/ref=mp_s_a_1_2?ie=UTF8&qid=1510596209&sr=8-2&pi=AC_SX236_SY340_FMwebp_QL65&keywords=diesel+compression+tester&dpPl=1&dpID=51lvnfmgwlL&ref=plSrch this one to be exact. But it didn't have the correct connector. Re: piston rings for Fazer 600 - edclarke - 13-11-17 Hi Mate , rebuild is going well (so far) , top end of the engine is at the engineers for a head skim and reseat of the valves and i'm having the bores honed prior to fitting the rings , Im just waiting for an engine gasket and seal set that seems to be taking ages to arrive. I did a compression test with my father in law , compression was down on 3 of the 4 cylinders but temporarily came back up when we squirted oil down the bores , which my father in law (who knows more about these things than i do) diagnosed as Ring wear , which was subsequently confirmed by the guy whose skimming the Head. Re: piston rings for Fazer 600 - unfazed - 13-11-17 (13-11-17, 06:55 PM)daviee link Wrote: easiest way is to place the ring in the barrel and measure the gap you do this in two places one about a inch down from the top of the bore and second about an inch up from the bottom that way you can tell ring wear and bore wearRepeat the above process with new rings to determine if the bore requires replating as they are nikasil plated bores, don't forget to check the ring side clearance, with the old and new rings. |
