Swingarm dimensions / swaps - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Swingarm dimensions / swaps (/showthread.php?tid=78970) |
Swingarm dimensions / swaps - F4celess - 26-10-17 Can anyone kindly confirm the exact width of the Swingarm at the pivot bolt - where it fits into the Frame? Im considering this for a swingarm conversion. Will then look into the options. Would be easier to space one out than have to "reduce" the width.... Re: Swingarm dimensions / swaps - brooker81 - 27-10-17 I've mine out at the moment(changing mine to something less steel girder) I'll measure it tonight for you pal. Hope you've got a lathe hanging around as you need to make/have made a few bits to make it if and also have to mod the frame depending on which swinger your going for Re: Swingarm dimensions / swaps - Andy1970 - 04-11-17 http://foc-u.co.uk/index.php/topic,22744.msg262821.html#msg262821 |
