FOUND ONE - Wanted - FZS 600 Boxeye right hand mirror - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: FOUND ONE - Wanted - FZS 600 Boxeye right hand mirror (/showthread.php?tid=78837) |
FOUND ONE - Wanted - FZS 600 Boxeye right hand mirror - HarryHornby - 23-09-17 Hi All, after a right hand mirror for my 51 plate boxeye. I would prefer an original one so it matches the left one. Cheers in advance. Re: Wanted - FZS 600 Boxeye right hand mirror - Fazerider - 23-09-17 FYI, the aftermarket ones M&P have are a good match appearance-wise for the OEM mirrors. However, the curvature of the mirror itself isn't quite so good... the view you get is a bit distorted towards the edges. Re: Wanted - FZS 600 Boxeye right hand mirror - unfazed - 24-09-17 I have one of these, will check later to see if it is OEM Re: Wanted - FZS 600 Boxeye right hand mirror - HarryHornby - 02-10-17 Hi Mr Unfazed, did you get to check the mirror?
Re: Wanted - FZS 600 Boxeye right hand mirror - unfazed - 03-10-17 Sorry Harry, I completely forgot , I will check in the morning, I know I have the shorter R1 Models just need to check if I have the slightly longer Boxeye ones Re: Wanted - FZS 600 Boxeye right hand mirror - unfazed - 04-10-17 No luck Harry, :'( It is only the shorter R1 ones I have left, must have sold the others. Re: Wanted - FZS 600 Boxeye right hand mirror - HarryHornby - 05-10-17 No worries, thank you for replying and for looking. Re: Wanted - FZS 600 Boxeye right hand mirror - juperwort - 14-10-17 I have the one I took off my 98. Went longer mirrors. How can I tell OEM? Re: FOUND ONE :-) Wanted - FZS 600 Boxeye right hand mirror - - HarryHornby - 17-10-17 Hi Juperwort, thank you for your reply. I've actually managed to source one now. Re: FOUND ONE - Wanted - FZS 600 Boxeye right hand mirror - robbo - 17-10-17 Glad you're slowly getting the bits together that you need Adrian :thumbup .Maybe the Whitstable Xmas run?? |
