Fork Seals..with video - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fork Seals..with video (/showthread.php?tid=78833) Pages:
Fork Seals..with video - anutz - 22-09-17 MOT Failed, leaking fork seal... I noticed some tiny scratches on the stanchion, and the MOT man said i could do the seals again, but will most likely just leak.. Reason for post is has anyone dealt with scratches..? Anutz Re: Fork Seals.. - SkidT - 22-09-17 Cant help with polishing out the scratches, but I had similar issues with my forks last year. Garage Changed the seal, but it blew again shortly afterwards. When it was stripped down again, there were tiny vertical scratches that had been caused by a worn bush. It wasn’t very easy to see with the fork in situ. A new stanchion was £160 (from memory) from Yamaha plus the seal, bush, oil and labour etc. I ended up doing them both in the end. ? A lot of money, but that’s after four years of ownership of with zero depreciation, so can’t really grumble. Good luck with whatever you decide to do. ? Re: Fork Seals.. - cl1ve2004 - 22-09-17 I had similar small vertical scratches in the chrome on mine..used a "rubber" type of block taking it very steady until they polished out (in the vertical) but not through the chrome finish..scratches still there but not as bad..did the fork rebuild using new bits,and factored in cost of new stanchions but all ok so far.. keep my eye on the seals for weeping.. :'( Re: Fork Seals.. - ram - 22-09-17 try this first - often just grit stuck to the seal https://www.youtube.com/watch?v=S5L2K2PXGtA Re: Fork Seals.. - anutz - 24-09-17 Didn't work... I have seals on the way, but a question, i have seen 2 approaches to doing Seals... One dismantles the entire fork, including taking out the damper rod.....then drivers the seal in etc The other, simply uses a Oil Seal puller to remove the old one, and then drive the new one in, fork stays 99% intact.. I am tempted just to remove the forks, pull the oil seal, and slide the new one on, drive it home with a driver i have...why dismantle the entire thing, afterall it going the gap between the inner and out tube, which is be definition accessible whilst the things are together... ? Re: Fork Seals.. - Hugh Mungus - 24-09-17 It can be tricky to get the old seal out without causing damage to the forks so be careful. I won't say 'Don't do it like that' as I've done it myself but the last time I tried the seal wouldn't budge and I had to strip the fork down. It is easier than it sounds and didn't take too long. Re: Fork Seals.. - Falcon 269 - 24-09-17 The fork bushes are prone to wearing quite early on the Gen 1 and it would be a good idea to change those at the same time as doing the seals. Just my five pennyworth.
Re: Fork Seals.. - anutz - 24-09-17 Hi All, Thanks for the input, i think i will just go the whole hog and take the forks to bits today, wait for my seals and driver ( got a universal one so i can fo 40-50 diameter forks, so will pay for itself when other bikes need em doing ) I shall have a look at the bushes as well, will be stripping them down today so might post some pics... Thanks Anutz Re: Fork Seals.. - anutz - 24-09-17 Forks out, top cap loosened, now, if anyone has any pointers, the damper rod bolts at the bottom, if it has them, should i crack them open now and back them out.... Re: Fork Seals.. - Falcon 269 - 24-09-17 You might this useful: http://www.yamahafz1oa.com/forum/showthread.php?t=67950 Re: Fork Seals.. - anutz - 24-09-17 time to make a tool i think....thanks Falcon269.... Re: Fork Seals.. - anutz - 24-09-17 So closer look at the stanchons, lots of wear and scoring on them, vertically, so assume the bush has worn, both are the same, so looks like i will need new ones, no point with doing it with these, as i doubt they will seal properly again, i can feel the grain with my fingernails, so its not ideal... any ideas on the stanchions, can see its going to be a 200$ job as each one looks like 110 on the bay... this bike is costing me an arm and a leg lol, and teaching me a few lessons. Re: Fork Seals.. - anutz - 24-09-17 OK go some bits out, waiting for some tools before i get the damper out and seperate the tubes.. But for now here is a video, and note the scoring after i pick the phone back up, had to put it down to pull the inner tube up and out a bit https://vimeo.com/235235943 So suspecting to see a bush thats had better days, i dont know how to tell but the scoring is the same on both forks so at 47K maybe that can happen, no idea.. Re: Fork Seals..with video - SkidT - 24-09-17 If it makes you feel any better Anutz, my Gen1 has about 22k on it. My grooves / scratches weren't anywhere near as long as yours, in fact they appeared pretty insignificant. They were however still sufficient enough for them to blow two sets of seals within a short space of time and mileage. Hence replacing both stanchions / bushes in the end. Done a few miles on it since and they're fine now. I went for OEM parts. Good luck. ? Re: Fork Seals..with video - anutz - 24-09-17 Thanks SkidT Where did u get stanchions from? also i assume you did bushes as well? Looking on the usual places and all seems available and fair price for what it all is i suppose, so i don't mind doing it Probably will keep it now once all serviced as have done so much on it else where, to sell it would be a waste of the effort i have put in... Re: Fork Seals..with video - anutz - 24-09-17 Checked out what i need on Fowlers, not too bad but a bit more than OEM i.e. 100 more, however i think if its parts like this then it may be best to stick with OEM unless anyone has used non OEM and got a good result. Re: Fork Seals..with video - old son - 25-09-17 I bought some R6 forks on eBay for £100. Worth considering. Straight swop apart from bracket for mudguard. Re: Fork Seals..with video - anutz - 25-09-17 Howdy old son... Thinking of alternatives now, i.e. 2nd Hand FZS1000 forks, or some R6 forks... Is it a certain year of fork that are needed? Thanks Chris Re: Fork Seals..with video - old son - 25-09-17 I used forks ref 5SL model R6 and upgraded the springs to 0.95 kg/mm from K-Tech. They have been on for 5 years now. Re: Fork Seals..with video - anutz - 25-09-17 Found this set, look good, but caps are different color, mine are blue? http://www.ebay.co.uk/itm/Yamaha-FZS1000-5LV-Fazer-Forks-2003-2004-2005-/263211532753?hash=item3d48a141d1:g:WtcAAOSw~G1Zvac0 |
