datatool alarm removal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: datatool alarm removal (/showthread.php?tid=78775) |
datatool alarm removal - Flooky - 11-09-17 Any body done it ? When I bought the bike it had been disabled (dunno how ) not had any problems with it but would like it gone and loom back to normal. Maybe I should leave well alone. Re: datatool alarm removal - icky - 11-09-17 I only removed mine last week, very straight forward really, just trace the wires from the alarm and into the bikes wiring loom, then remove the black wires from the loom. there will be two wires in the loom you will need to reconnect, these are what creates the immobilising side of the alarm. The other wires are for the indicators and are only attached to the side of the loom wires, these I just cut the black wires off with out cutting the loom and them tapped over. Then just re tape the loom back making sure the bike starts first.
Re: datatool alarm removal - Flooky - 11-09-17 Cheers, what about starter motor wire etc ? is it just one wire that imobilises? Re: datatool alarm removal - Flooky - 11-09-17 Seem to have 7 black wires going into loom, one going to seat switch one going to battery and one going to led light. ten in all, I just put the seat back on and came in for a beer, cos I am a scaredy cat. Its running fine, had it 2 plus years and done 5000 miles, wonder if I just opening a can of worms ( if it aint broke etc etc ) Re: datatool alarm removal - icky - 11-09-17 (11-09-17, 04:27 PM)Flooky link Wrote: Cheers, what about starter motor wire etc ? is it just one wire that imobilises?It depends how good the alarm fitter was, there is usually two, one for the ignition side and one for the fuel pump. If you're not confident it is probably best left alone especially if there are no issues at the moment. I had no choice with mine, I would disarm the alarm and hit the starter but nothing would happen until I rattled the alarm box! Re: datatool alarm removal - Flooky - 11-09-17 yeah I think I will think about it and do it when I need a project, just cant see how the fella disabled it originally. Its a neat job ( the fitting ) but how would someone disable it ? any way cheers, I will bugger it up another day when the weather has really gone away for good. Re: datatool alarm removal - Rob - 12-09-17 they open up the connector blocks and put wire between certain holes. I lost my fob key on a thunderace many years ago took rac man about ten minutes talking on his phone as he by passed it using two bits of fuse wire it was lit up like a christmas tree doing the process, i had the ignition key and just started straight away |
