Datatool system3 removal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Datatool system3 removal (/showthread.php?tid=78731) |
Datatool system3 removal - Woodzey80 - 03-09-17 Anyone removed one from a gen1 thou ? If so was it difficult ? Re: Datatool system3 removal - FILZ6 - 03-09-17 Not difficult as such, but time consuming. Take your time, address one wire at a time. All the wires on the alarm are black, no id, so if you don't label them yourself before you start it is non reversible. Alarm wiring is spliced/soldered into the bikes wiring, remove them then re-solder the colour matched original wiring back together. One at a time. Must confess I was worried when I tackled mine, but had no problems. Off memory took me an afternoon, but I did tend to fanny on checking then double checking, worked out well in the end. Good riddance to datatool. Dis-connect the battery before you start. Good luck. Re: Datatool system3 removal - Woodzey80 - 03-09-17 Thanks a lot for the reply, I will take the job on myself then when I get some spare time. Cheers Re: Datatool system3 removal - Woodzey80 - 16-09-17 SORTED !! Sorry the site won't let me upload a pic |
