Lube my pivot - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Lube my pivot (/showthread.php?tid=78602) |
Lube my pivot - fazersharp - 13-08-17 Whilst out today I noticed the front brake leaver a little bit sticky/notchy when I pull in. A while back some one had the same issue and I think they just took the leaver off - gave it a clean and re - greased but I can not find the post about it. So just checking I undo the nut and bolt holding the leaver on, the piston isn't going to pop out or something stupid is it. Re: Lube my pivot - darrsi - 13-08-17 No, it's literally a nut and bolt, not spring loaded or anything. (open link below) Re: Lube my pivot - darrsi - 13-08-17 Lube the piston part as well, that can cause issues too. Re: Lube my pivot - darrsi - 13-08-17 http://foc-u.co.uk/index.php/topic,20142.msg232458.html#msg232458 Re: Lube my pivot - fazersharp - 13-08-17 (13-08-17, 10:25 PM)darrsi link Wrote: http://foc-u.co.uk/index.php/topic,20142.msg232458.html#msg232458That's fantastic and just the info I was looking for thank you. its not even as bad as your seemed I have just caught it at an early stage, I will inspect the pivot hole when I take the leaver off, yes I only dolow milage but they are all bendy dry weather miles .Lube being washed out is not my problem its being dried out that is. Re: Lube my pivot - fazersharp - 21-08-17 All done, removed leaver and cleaned away almost non existent grease that was also dry, cleaned around piston rubber and added some red rubber grease there and a smear of normal grease around the pivot, all feels good now but will see how it feels on a proper road test. Should of done it sooner :o |
