Clutch lever pivot bolt - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Clutch lever pivot bolt (/showthread.php?tid=78593) |
Clutch lever pivot bolt - Paclampet - 11-08-17 Hi folks I hope someone can help. Have gone to swap my OEM clutch lever for a new after market part on my 2003 Fazer 600 and ... Ive gone and sheared the pivot bolt when removing the lever!!!! :'( Simple question. Where can I get a spare? Appears to be a 10mm bolt with the bush attached. A Web search hasn't actually offered much although Ive found a website called Yambits which seems to sell pivot bolts although it doesn't state for what bike. Will they be all a similar size? Will try Yam dealer tomorrow although I suspect I won't have much joy!! Yours hopefully Richard Re: Clutch lever pivot bolt - bandit - 11-08-17 I don't think your have much luck at a Yamaha dealer having one in stock but maybe quicker than getting one from my link but at least you will have the part number for dealer tomorrow. https://www.ajsutton.co.uk/product/yamaha/3YX839450000/bolt-lever?uid=0 Re: Clutch lever pivot bolt - darrsi - 12-08-17 In stock, number 12 (same part number for all models [color=rgb(51, 51, 51)]3YX-83945-00[/color]) https://www.fowlersparts.co.uk/parts/4165884/fzs600-fazer-5dm7-2000-070-a/handle-switch-lever Re: Clutch lever pivot bolt - Paclampet - 12-08-17 Thanks for your replies. Managed to source one at the local breakers - quick plug for them; http://www.sheffieldmotorcyclesalvage.com. All sorted now then...... set off out to find I have a slow chufffin' puncture :wall >: FFSakeeeee!!!!!!! |
