Speedo not working - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Speedo not working (/showthread.php?tid=78559) |
Speedo not working - reggit - 04-08-17 Hi all, Next question - my speedo isn't working. Can someone point me in the direction of the pickup please? Re: Speedo not working - BBROWN1664 - 04-08-17 gearbox Re: Speedo not working - reggit - 04-08-17 (04-08-17, 10:34 AM)BBROWN1664 link Wrote: gearbox Do you mean on front sprocket? Re: Speedo not working - reggit - 04-08-17 Found a decent thread on the subject, so please ignore this one. http://foc-u.co.uk/index.php?topic=476.0 Re: Speedo not working - Gaz66 - 04-08-17 Check the multi-plugs under left headlamp fairing infill panel, all live feeds to clocks & lights go thru these plugs. Any corrosion or bad connection at all in these plugs will cause a whole load of electrical gremlins, from no lights at all, to flickering clocks, to no speedo etc. It's a very time consuming job pulling every wire from the plug to clean em up, I stripped/cleaned every plug on my full loom, everything now works mint[size=0.7em].[/size] Re: Speedo not working - reggit - 04-08-17 Ignore this! Re: Speedo not working - reggit - 07-08-17 and this! - wrong information Re: Speedo not working - stuck! - reggit - 09-08-17 More info - and I'm stuck! Have continuity from instrument cluster white wire to speed sensor plug white. 4.8v on white at speed sensor plug - sensor disconnected 0v at plug with sensor connected with instrument console plug disconnected the voltage at the sensor is 4.8v with the sensor connected or not - not switching when bike moved (no centre stand) I've bought a new (used) sensor, but it's doing the same, which sort of rules the sensor out. The multiplugs under the infill panel are not corroded. Re: Speedo not working - reggit - 19-08-17 I'll just put the solution in my case on here in case someone reads it in the future. I found a fault in the instrument cluster - it smelt of burning circuitry when I opened it. Suspect this killed the 2nd sensor, as it initially tested ok. Bought a cheap used set of clocks and another sensor and it now works. |
