shared carbs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: shared carbs (/showthread.php?tid=78357) |
shared carbs - Disorderlypunk - 26-06-17 anyone happen to know if the 2k boxeye shared its carbs with any other model - im looking at some k+n filters for a 99 fzr600 and they are pretty close to my sketchy dimensions (good verniers battery flat so using my cheap as fuck plastic ones which are no good for precise measurements) - seen the price of the ones rubyracing used and found some cheaper ones which might work better for harmonic resonance if they fit Re: shared carbs - daviee - 26-06-17 as long as you are close i dont think it has to be that accurate they will be in mm not any less that that Re: shared carbs - Disorderlypunk - 26-06-17 it looks like its only a few mm out between inlet centers 1&2 3&4 - prob close enough for the rubbers to allow the difference Re: shared carbs - daviee - 27-06-17 i would think so as the carbs must be spaced about the same at the inlet rubbers are the same through out that engine type as are the engines |
