Quick action throttle - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Quick action throttle (/showthread.php?tid=78313) |
Quick action throttle - fireblake - 19-06-17 I've been having a bit of a problem with my wrist and was wondering if any of you guys use a quick action throttle on their Thou' and does it make for an easier ride? Thanks,. Mickey Re: Quick action throttle - BBROWN1664 - 19-06-17 Nt used one but I would have thought it made for a harder ride as throttle inputs would be magnified so not as easy to apply small changes Re: Quick action throttle - Gaz66 - 19-06-17 Quick action throttles tend to pull a lot of cable per degree of rotation, so might be a bit aggressive on a "Thou"?...Perfectly fine on a track bike but a rd bike needs a bit more throttle finesse. Apparently an R6 throttle tube has a larger cable drum, hence pulls more cable than a standard Gen 1 "Thou" throttle tube, not as aggressive as a full on quick action but better than a "Thou" (apparently) ? I'm considering getting one for mine. Not sure if throttle housing will need some mods but it's been done before so i guess all the info is on web somewhere. Cheap enough new, loads on Fleabay. Rgds Gaz Re: Quick action throttle - fireblake - 19-06-17 (19-06-17, 07:53 PM)Gaz66 link Wrote: Quick action throttles tend to pull a lot of cable per degree of rotation, so might be a bit aggressive on a "Thou"?...Perfectly fine on a track bike but a rd bike needs a bit more throttle finesse.Interesting. I have small hands and bad wrist pains from a few broken wrists as a kid so a shorter action would suit me. I suppose the aggressiveness could be tuned out with getting used to it like most things. I'll have to look into the R6 option. Thanks Mickey Re: Quick action throttle - b1k3rdude - 19-06-17 Would having large grips (as in heated grips, off in this weather obviously) but it make it much easier I have found to turn the throttle Re: Quick action throttle - fireblake - 19-06-17 That's another good idea Mickey Re: Quick action throttle - slimwilly - 05-07-17 R6 tube on mine, works very well, gen 2, all the worries of jerkiness, harsh action is utter rubish Re: Quick action throttle - fireblake - 05-07-17 Thanks Slim, do you think this would work OK on a Gen1? Is it just a change the part mod. One for one? Mickey Re: Quick action throttle - old son - 05-07-17 I fitted one to a ZX10R which was ridden on the road 99% of the time. You soon get used to the throttle and it was very easy to ride. I would do it if I were you. Re: Quick action throttle - slimwilly - 06-07-17 (05-07-17, 11:46 AM)fireblake link Wrote:Thanks Slim, do you think this would work OK on a Gen1? Is it just a change the part mod. One for one?Not sure mate, demote I think , £10, |
