Seized fork bottom adjuster - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Seized fork bottom adjuster (/showthread.php?tid=78289) |
Seized fork bottom adjuster - bwizz - 14-06-17 Just doing the fork seals on my thou .The bottom compression "flat blade screwdriver adjuster" is seized.! Can I remove the threaded housing that surrounds it to gain access. Just checking before anything goes pyoing! Re: Seized fork bottom adguster - cl1ve2004 - 14-06-17 loads of threads on this..good penetrating oil and heat (not too much!!) I had same thing on mine.. best thing is patience.. loads of info if you use "search "on here.. good luck :rolleyes Re: Seized fork bottom adguster - Mustang - 14-06-17 I've done a YouTube on this when I did my zx9r forks. Re: Seized fork bottom adguster - bwizz - 23-06-17 What happens if I remove the boss which holds the adgusting screw ? Re: Seized fork bottom adjuster - cl1ve2004 - 23-06-17 others know more than me,but I think its got a really fine thread that is really easy to foc up and then its a replacement fork bottom!! theres a picture on the threads which shows a seized one cut through section... Re: Seized fork bottom adjuster - bwizz - 23-06-17 Hard to browse the site with a phone. ! But thanks! Re: Seized fork bottom adjuster - Mustang - 30-06-17 Ktec do replacement adjusters Re: Seized fork bottom adjuster - bwizz - 01-07-17 I got sidetracked .i'm gona take the forks of again next week .and have another go .I'll report back thanks all! Come to do the seized forks adjuster yesterday. I removed offending fork leg and drained oil. I removed the adjuster boss no probs. Observed that the adguster screw is brass so heat is not going to do much. Tried it didn't . Tried impact screwdriver no go .well stuck! Desperation now! I cut a slot all around the screwhead approx 3 mil in . Then broke away the surrounding alloy ring. I was intending to get at the screwhead with mini mole grips! I was surprised to see that the adjuster srcew is in two parts slotted together! I removed the seized outer screw and the inner brass screw adgusts fine. Not having or at that point realising I would need a new one. I decided to see if all was well when I refilled with oil. No leaks but no click adjustment now so just counted the turns compared to the other side. I fitted a rubber blanking gromet over the recessed screwhead and all seems to be well. I will probs fit a new adjuster when the messing mood is on me again. Not much oil came out of the boss so I don't think an issue to do in situe ! Progably a good idea to locktite the brass screw if you are faced with this problem. |
