'04 Fazer 1000 clutch - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: '04 Fazer 1000 clutch (/showthread.php?tid=78216) |
'04 Fazer 1000 clutch - greg1953 - 28-05-17 Just got back from a ride and noticed the clutch felt odd, pulling the lever it feels like a two stage trigger on a gun with a very definite change half way through the travel, it's not the lever as I pushed the lever on the clutch cover and the same can be felt, any ideas before I pull it to bits ? Greg Re: '04 Fazer 1000 clutch - unfazed - 28-05-17 Spay some WD40 on to the lever pivot on the clutch cover first before you start pulling it apart. Operate the clutch a few times while spraying. Re: '04 Fazer 1000 clutch - SkidT - 31-05-17 Could it possibly be a fraying cable snagging on the sleeve / lining? When was the last time that was changed or the inner cable lubed? Just thinking cheap possibilities first? |
