Water leak - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Water leak (/showthread.php?tid=78114) |
Water leak - Curly - 13-05-17 Hi, when I moved the bike today I noticed a small amount of coolant on the floor. I've traced it back to the filler cap under the right fairing panel or maybe the join of the rubber pipe just underneath. It's hard to tell. The coolant is filled right to the top of the filler neck and I've checked the small tank behind the engine and the coolant is between the level markers. ( it's low but between the marks ) I've cleaned everything and run the bike till hot and can't see anything leaking. Can anyone give me any advice on what else I should be checking ? The coolant hasn't been changed or topped up in about 3000 miles so it's nothing That's been done to the bike recently. It's a gen 1 fzs1000 |
