Carb vacuum pipe caps - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Carb vacuum pipe caps (/showthread.php?tid=78064) |
Carb vacuum pipe caps - matt7chunk - 04-05-17 hi guys, does anyone know where i can purchase the little rubber caps that go on the vacuum pipes on carbs? cant find them anywhere cheers Matt Re: Carb vacuum pipe caps - Disorderlypunk - 04-05-17 im one short aswell so if you find any let me know Re: Carb vacuum pipe caps - matt7chunk - 04-05-17 will d, also i cant find any STANDARD clutch springs only the heavy duty ones witch i hear a lot of horror storys about Re: Carb vacuum pipe caps - Bretty - 04-05-17 The rubber caps are usually in stock at most Yamaha dealers or available on order after a couple of days. Have a ring around. They're only £2 or £3 with the clip. Re: Carb vacuum pipe caps - Bretty - 04-05-17 Pt# 16G135690000 Re: Carb vacuum pipe caps - Jamieg285 - 04-05-17 They're only rubber caps. No need for genuine Yammy ones. Just find the internal diameter you need and they're easy to find. Re: Carb vacuum pipe caps - darrsi - 04-05-17 AJ Sutton website if you get stuck. Re: Carb vacuum pipe caps - bikemad - 04-05-17 I've got a few could spare a couple for members ? Re: Carb vacuum pipe caps - matt7chunk - 04-05-17 I think I only need 2 haven't dug deeper into the middle carbs but can see them cracking on the outside one Re: Carb vacuum pipe caps - jimjenko - 04-05-17 http://www.ebay.co.uk/itm/351672683287?_trksid=p2060353.m2749.l2649&var=620648046464&ssPageName=STRK%3AMEBIDX%3AIT 4mm ones fit Re: Carb vacuum pipe caps - matt7chunk - 04-05-17 ooooo red ones! :eek Re: Carb vacuum pipe caps - bikemad - 04-05-17 (04-05-17, 03:22 PM)jimjenko link Wrote: http://www.ebay.co.uk/itm/351672683287?_trksid=p2060353.m2749.l2649&var=620648046464&ssPageName=STRK%3AMEBIDX%3AIT At that price buy new ones you can select the colour to match your bike ? |
