Idle compare - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Idle compare (/showthread.php?tid=78063) |
Idle compare - kgjersda - 04-05-17 Hello, How would you compare my running idle with an optimal setting? https://www.youtube.com/watch?v=sbsPuixz4Lw I have tried balancing the carbs, the spark plugs are very new (NKG CR9E). https://www.youtube.com/watch?v=PuOi51qVZco (How do I embed video?) Re: Idle compare - Bretty - 04-05-17 Mines probably the same cold and super smooth when warmed up after a good motorway run. Just turn up the tickover on the carbs a notch if it bothers you. someone will be along in a minute to suggest you check or renew your air filter, although you're meant to do that before you balance the carbs. Re: Idle compare - kgjersda - 04-05-17 Ah yes, forgot to mention that I already changed for a new DNA air filter. Thanks for confirming that it's around where it should be
Re: Idle compare - Jamieg285 - 04-05-17 TBH, I can't really see much of an issue there. I slight flutter, but nothing serious. - How much time do you spend idling vs riding? If it was me, I'd have been more of a perfectionist and got closer on the carb balance, but I'd say you were within acceptable levels. |
