gold plate in sprocket cover???? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: gold plate in sprocket cover???? (/showthread.php?tid=78027) |
gold plate in sprocket cover???? - Disorderlypunk - 28-04-17 just had the sprocket cover off and it was full of crap (no suprise) so coated in degreaser to do its stuff while doing some other stuff and a goldish plate appeared anyone know what is under there ? just wondering as it may now be full of degreaser and might need regreased if important Re: gold plate in sprocket cover???? - Bretty - 28-04-17 I'm sure this came up the other week, either on here or the facebook page. Apparently its just a weight to reduce vibration on that plate and into the clutch and gear mechanisms. Re: gold plate in sprocket cover???? - Fazerider - 28-04-17 Yes, there’s nothing underneath it. It’s called a dampening plate and is supposed to reduce noise. They left it off later years so it can’t have been very effective. It is useful in a way that Yamaha did not intend: when the sprocket nut loosens itself, the plate prevents it falling off the end of the shaft. This means the earlier Fazers are less likely to suffer serious damage to the thread on the shaft as, with the remains of the nut in the way, the sprocket is not able to move across that far. Re: gold plate in sprocket cover???? - Disorderlypunk - 28-04-17 great - i found it was called a damping plate on a microfiche but had no idea thats what must have kept my sprocketnut on cause after 90k it still had the original nut -new 12mm nut bought as it is totally goosed now lol -cheers guys Re: gold plate in sprocket cover???? - fazersharp - 29-04-17 (28-04-17, 01:06 PM)Disorderlypunk link Wrote: just had the sprocket cover off and it was full of crap (no suprise)Degreaser ! it couldnt of been that bad as I had to clean mine with a spoon the first time i did it. Here it is and yes its just a noise damping plate, I tried to get it off but the screws are made out of cheese and glued in with locktite so I gave up. [img height=1000 width=667]http://foc-u.co.uk/index.php?action=dlattach;topic=22264.0;attach=28814;image[/img] Re: gold plate in sprocket cover???? - Creaky - 13-08-17 After owning my bike since June I've just had the sprocket cover off on my 2001 600 Fazer to check what the condition was like behind and I also had to dig out the crud that had built up over the years. Got it all clean, checked the sprocket nut which is 9mm deep which was all secure and then tackled the gasket issue. Wasn't keen on buying and waiting for a new gasket each time I remove the cover as I see it as a routine operation to keep things in good order. I've applied a thin layer of black silicone to the outer cover edges and smoothed this out to make what I hope will be a permanently attached reusable seal. I let it dry overnight and then applied a smear of grease to the opposite face on the bike and refitted. My theory is that the grease will prevent the silicone attaching itself to the bike and enable it to detach without problem during my future checks. I've heard of folk using grease between paper gaskets to enable them to be reused so hopefully the plan will work! My silicone bead is thicker than the original gasket so I was concerned that it may affect the clutch pushrod operation but a after a test run this afternoon all seems fine. Re: gold plate in sprocket cover???? - fazersharp - 13-08-17 (13-08-17, 07:47 PM)Creaky link Wrote: After owning my bike since June I've just had the sprocket cover off on my 2001 600 Fazer to check what the condition was like behind and I also had to dig out the crud that had built up over the years. Got it all clean, checked the sprocket nut which is 9mm deep which was all secure and then tackled the gasket issue.Actually you don't even need a gasket there, and from my extensive DIY around Sharp Hall with silicone I think that you will find that it will still peel off in pieces especially as it has been squeezed so thin that the thickness has not altered the clutch operation Re: gold plate in sprocket cover???? - Disorderlypunk - 13-08-17 i wouldnt bother with the gasket but if you really want something there use a gasket compound as its designed exactly for that job Re: gold plate in sprocket cover???? - unfazed - 14-08-17 (29-04-17, 10:42 AM)fazersharp link Wrote: [quote author=Disorderlypunk link=topic=22477.msg259484#msg259484 date=1493381204]Degreaser ! it couldnt of been that bad as I had to clean mine with a spoon the first time i did it. Here it is and yes its just a noise damping plate, I tried to get it off but the screws are made out of cheese and glued in with locktite so I gave up. [/quote] Why were you rying to remove it? Nothing behind it except a big piece of rubber. I have added this plate to three 2003 bikes because it prevents the sprocket nut from falling off and thus preventing the sprocket from falling onto the threads and destroying them, a worth while addition to the any 2002/2003 bikes. Re: gold plate in sprocket cover???? - fazersharp - 14-08-17 (14-08-17, 12:37 AM)unfazed link Wrote: [quote author=fazersharp link=topic=22477.msg259548#msg259548 date=1493458926]Degreaser ! it couldnt of been that bad as I had to clean mine with a spoon the first time i did it. Here it is and yes its just a noise damping plate, I tried to get it off but the screws are made out of cheese and glued in with locktite so I gave up. [/quote] Why were you rying to remove it? Nothing behind it except a big piece of rubber. I have added this plate to three 2003 bikes because it prevents the sprocket nut from falling off and thus preventing the sprocket from falling onto the threads and destroying them, a worth while addition to the any 2002/2003 bikes. [/quote] It then would of made it easy clean the whole lot with that out of the way that's all Re: gold plate in sprocket cover???? - Carter - 14-08-17 So they knew the sprocket nut would come off ? ? ?
Re: gold plate in sprocket cover???? - fazersharp - 14-08-17 (14-08-17, 06:51 PM)Carter link Wrote: So they knew the sprocket nut would come off ? ? ?No - its a noise dampener on the very early ones - |
