Led light - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Led light (/showthread.php?tid=78016) |
Led light - chrischristopherson1313 - 26-04-17 Changed indicators to led and they doesn't work when headlight is on. Do I need to change H4 bulb to led as well. Normal bulbs indicators works fine. Check on both relays (led and oem) Re: Led light - slappy - 27-04-17 I could be wrong here but don't you need to fit some sort of inline resistor to get led indicators to work correctly? Re: Led light - chrischristopherson1313 - 27-04-17 (27-04-17, 08:03 AM)slappy link Wrote: I could be wrong here but don't you need to fit some sort of inline resistor to get led indicators to work correctly? I put led relay so indicators works fine. Only when I turn lights on they stop working. Re: Led light - slappy - 27-04-17 I would check that all your earth points are good, clean them up and use contact cleaner on all connectors, check any wiring you might have disturbed when fitting the relay and indicators. Re: Led light - BBROWN1664 - 27-04-17 Sounds like a wiring issue. Re: Led light - Bretty - 27-04-17 The wiring diagram in the Haynes manual is pretty handy when fault finding the lights and indicators. |
