R6 shock upgrade - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: R6 shock upgrade (/showthread.php?tid=77980) |
R6 shock upgrade - Gaz66 - 22-04-17 Hi Peeps. Not long since joined FOCU. Some interesting reading on here. Upgraded from a very modified & tuned Kawy ZRX 1136R. In it's place is a Silver 53 plate bog standard Fazer 1000. Way better bike IMHO. My question is, which year R6 shock works best on a Fazer 1000 & what's the correct length of the dog bones required? As I've heard R6 shocks are a tad shorter, so I assume different length dog bones will be required to bring ride height back to original. I may fabricate my own? but if anyone can recommend a supplier I'll try that option if the price is right. Thanks in advance, any info is mucho appreciated.. Rgds Gaz (Barnsley) Re: R6 shock upgrade - robbo - 22-04-17 Gaz, If you send a pm to devilsyam, he will give you all the info you need if you want to go the R6 shock route.He'll supply everything and ensure the shock is set up for your weight etc. He is the R6 shock guru for FZS thou's. Re: R6 shock upgrade - PieEater - 24-04-17 If you have a look in the FAQ there is a link to Luke's page where he shows you the correct shock to buy. Re: R6 shock upgrade - devilsyam - 24-04-17 or send me a pm |
