Speedo bracket - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Speedo bracket (/showthread.php?tid=77952) |
Speedo bracket - StuSid - 19-04-17 Hey guys I know theres been loads of posts about a custom speedo bracket for a 'naked' conversion and ive even seen some decent ones. The best I seen was mounted where the bar risers were however I cant replicate it as I dont have the tools or metal to do this... I was curious if anyone actually makes these or something similar I could possibly buy or even an old one that worked great I would buy. This will only be temporary to get me back running again until I fix the shitty projector conversion someone did and repair the slight damage to the fairings which I plan to do this winter while shes stored away. Cheers everyone. Re: Speedo bracket - celticdog - 19-04-17 Hi Stu, I'm not sure if you can buy something off the peg as it where, but if you can draw up exactly what you're after there are lots of little fabricator workshops who could produce what your after at a reasonable cost Depending on where you live, I'm sure there's someone with reasonable rates.
Re: Speedo bracket - joebloggs - 20-04-17 If its only short term why not leave it bolted to the stock fairing subframe inc lights, won't look great but will save you splashing out on a custom made bracket Re: Speedo bracket - Disorderlypunk - 20-04-17 at the moment mine is still stuck on the original bracket with the rest chopped off and the dominator lights mounted on fork brackets it dont look pretty but it looks better than the shattererd and twisted fairing that was on when i bought it Re: Speedo bracket - StuSid - 20-04-17 (19-04-17, 03:40 PM)celticdog link Wrote: Hi Stu, I'm not sure if you can buy something off the peg as it where, but if you can draw up exactly what you're after there are lots of little fabricator workshops who could produce what your after at a reasonable cost This is probably going to be what i will do, my uncle is a fabricator so ill see if he can sort me out! Cheers everyone |
