Fazer 2004 Gen 1 Oil Cap Issue - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fazer 2004 Gen 1 Oil Cap Issue (/showthread.php?tid=77881) |
Fazer 2004 Gen 1 Oil Cap Issue - hopskimoet - 09-04-17 Just recently purchased a FZS1000 2004 (23K) and during riding there is weepage at the oil filler cap. At first, I thought a gasket had failed as the oil was collecting under the clutch cover. I have tightened the oil filler cap as tight as it will go and still she weeps. I was thinking maybe a quick fix by using a few layers of PTFE (plumber's tape) as it does offer good heat resistance. Is this an inherent issue or is it something unique and an indicator of a deeper problem? Re: Fazer 2004 Gen 1 Oil Cap Issue - slappy - 09-04-17 There should be an 'O' ring fitted to the cap, check it is there / not damaged. Re: Fazer 2004 Gen 1 Oil Cap Issue - hopskimoet - 09-04-17 Of course... I'll check it... Is the washer bike specific? Or can I just use one from a kit? Re: Fazer 2004 Gen 1 Oil Cap Issue - slappy - 09-04-17 As long as the 'O' ring is a reasonably tight fit on the cap then any one will do. Re: Fazer 2004 Gen 1 Oil Cap Issue - hopskimoet - 20-04-17 Sorted. The 'O' ring was missing. Ordered one from Fowlers for £7 although I could have just used one from a standard kit. No drama though. Does anyone know what color silver I need to touch up the engine? Re: Fazer 2004 Gen 1 Oil Cap Issue - robbo - 20-04-17 RS Paints will have the necessary engine and bodywork paints .Just input your make/model/year. However other members have used alternative sources.A search will give you those answers.
Re: Fazer 2004 Gen 1 Oil Cap Issue - PieEater - 20-04-17 (20-04-17, 01:25 PM)robbo link Wrote: A search will give you those answers.As will checking out the FAQ
