Rattle in neutral - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rattle in neutral (/showthread.php?tid=77870) |
Rattle in neutral - scoobiemandan - 08-04-17 I've noticed of late that there appears to be a rattle when in neutral. Disappears when I pull in the clutch but is there when released. Also, sounds a bit like I have a nest of starlings in the gearbox when moving/accelerating! Any idea's fellow Foccers? Re: Rattle in neutral - PieEater - 08-04-17 Rattle in neutral that goes when the clutch is engaged is normal. Not sure about the nest of starlings though. Re: Rattle in neutral - Dustydes - 08-04-17 Rattle is standard noise with clutch, unless it's very bad. Prob just normal wear on clutch basket. If in doubt get it checked. Or pull cover and inspect. Check oil level, seems that near top of inspection glass is best. Re: Rattle in neutral - scoobiemandan - 08-04-17 Thanks guys, if I pull the cover, what am I looking for with regards to wear. Could the nest of starlings be clutch basket noise as well? It's not particularly loud, either the rattle or the starlings but I'm sure it's something that wasn't there before. Oil level appeared fine last time I had a quick look, certainly not low in any case. Re: Rattle in neutral - scoobiemandan - 11-04-17 Anyone? I have no idea what a worn clutch basket would look like! Give me a car and I'll diagnose and fix the problem, give me a bike and I haven't the foggiest :o Re: Rattle in neutral - The Male Whale - 11-04-17 The rattle is worse when the carbs need a balance. Whale Re: Rattle in neutral - scoobiemandan - 14-04-17 Thanks for that Whale although I'm inclined to think that's not the issue here but it's certainly something I'll look into once I've checked out the clutch basket and plates! I've just read somewhere else that dry plates can cause a squealing effect so perhaps this is my nest of starlings I speak of!? Re: Rattle in neutral - bludclot - 14-04-17 Once inside the clutch cover there's a plug that sits in the centre of the clutch assembly - it should be intact and in place rather than floating around inside, that's the first check point. Taking the plates out and measuring the total stack height and comparing to the manual specs is also easy, assuming you have access to a micrometer or equivalent. Genuine plates are cheap if I recall, should they be out of spec. The 'fingers' of the clutch basket are, ideally, smooth. Very slight grooving is acceptable but scores are a sign of wear. It's very easy to tell, a visual inspection or running a finger over them type easy. Gentle filing is fine but much material removal will lead to a rattly clutch. New baskets are expensive. If all the above checks out then removing the basket (a bit awkward as the holding nut is is tightened to a high torque, pulling the bike along or over is very possible) and inspecting the springs embedded in the back is next. My springs had large gaps between them and the basket back so I bit the bullet and had them tig welded to the basket at their 'push' end. (On the basis that if it didn't work I'd buy a new basket.) Once re-assembled my clutch has been quiet and perfect in operation for 6000 miles or so. I fully appreciate that this is a fairly drastic solution and not for everyone, but it worked a treat for me. Reassembly is straight forward enough (the time honoured 'reversal of removal') except re-torquing the basket bolt gives the same risks as removal and I found locating the pivot arm in the cover correctly fiddly and awkward, it took me several attempts before I was satisfied that it was right. Also bear in mind that cable adjustment makes a massive difference. Genuine cables work well, after market cables are pretty useless, I put this down to four right angles between the lever and clutch housing. Hope this helps. Re: Rattle in neutral - scoobiemandan - 14-04-17 Perfect, thanks blud
Re: Rattle in neutral - scoobiemandan - 14-04-17 Well, I've just checked free play and get around 10mm so all okay there! Cable movement is smooth and easy enough so all okay there! Chain tension is between 40-45mm all round, mostly closer to 45mm but still within range so all good there also! At the very least I need to get a gasket so I can check everything in the housing and put it all back together if nowt is wrong. Bike's only on around 39000 miles so I'm not thinking the clutch is due for renewal just yet but you never know! EDIT: I've just double checked the chain and it actually appears it may need adjusting so I'll do that first. Re: Rattle in neutral - Timbo - 29-06-17 (14-04-17, 09:09 AM)bludclot link Wrote:"Once inside the clutch cover there's a plug that sits in the centre of the clutch assembly - it should be intact and in place rather than floating around inside, that's the first check point." Re: Rattle in neutral - Falcon 269 - 29-06-17 Not sure you'll find a part number for the plug as it's oressed in during manufacture and thus an integral part of the mainshaft not a separate item. Well, not meant to be separate ...
Re: Rattle in neutral - Timbo - 29-06-17 (29-06-17, 03:34 PM)Falcon 269 link Wrote:Not sure you'll find a part number for the plug as it's oressed in during manufacture and thus an integral part of the mainshaft not a separate item. I see, well I will do when I get in there. Plastic I assume? |
